so i have a brand new setup and this is my first time booting and i get boot failure detected load optimized default's then boot load optimized defaults then reboot or enter bios then it says the system has experienced a boot failure possibly due to incorrect configuration previous settings in bios may not be compatible with current hardware and any time i try to click or move my selection and select one of the options nothing happens does anyone know what's going on and how to fix it
https://linustechtips.com/topic/1603784-help-with-biosstart-up/
51 minutes ago, gammer said:
no i dont really want to touch anything hardware wise incase i brick my board cause i dont got the money for a new one
Resetting the CMOS won't brick your board. As long as you're not in the middle of updating the bios and the system crashes or shuts off it should be just fine. That bios setting failure error you are getting is basically telling you to reset the bios to default settings either via the settings within bios "Load optimized defaults" or by doing a CMOS reset by simply removing the battery while the system isn't connected to wall power.
If you don't want to or aren't comfortable troubleshooting and trying things on the system that are recommended for troubleshooting or fixing it, you're going to need to take it to someone who is, which means(in most cases) paying them to do that.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1603784-help-with-biosstart-up/#findComment-16670923
