When I turn on my pc I see the logo of my motherboard manufacture and the option to go insto bios to do Q-flash and something else and then when it has to go to windows I get a black screen but the light on my motherboard that says that there is a problem with the gpu doesn't turn on. And I have to press on the reset button on my case and the it works but every time when it gets to windows it says update in progress even if there was not an update in the first place. How can I solve this?? Can this be caused by the fact that Windows is on an HDD??
https://linustechtips.com/topic/1603550-power-on-problem/
1 minute ago, --SID-- said:
Bad HDD maybe.
What are the full system specs includes the brand and model of the PSU?
Specs:
Ryzen 7 7700x
RX 6650 xt
PSU: Cougar Atlas650
16gp ram
The HDD is from segate 2tb
And I also have an ssd which I installed later from hp 1 tb
https://linustechtips.com/topic/1603550-power-on-problem/#findComment-16669601
I suggest you wipe both the HDD and the SSD. Then unplug the HDD. Next install a fresh Windows on the SSD. Once it is done, plug back the HDD.
You'll then have a super boot speed and an extra 2TB slower storage.
If the HDD is defective, you should see signs of problems as soon as you plug the HDD. Otherwise, it is entirely possible that you have corrupted windows files.
Good luck !
https://linustechtips.com/topic/1603550-power-on-problem/#findComment-16669632
