You need to find the "boot" menu in the BIOS first. Make the "870 Evo" the first item on the list.
Desktop benching:
https://linustechtips.com/topic/1602624-i-have-a-bias-problem/#findComment-16662461
2 hours ago, DivadRacso1000 said:
What the do in here?
If it's an older OS (Windows 7 or before) you need to enable CSM. Even if it isn't, it's a good way to try make it give you more options
Desktop benching:
https://linustechtips.com/topic/1602624-i-have-a-bias-problem/#findComment-16662569
