USB device over current status detected
Go to solution Solved by Tech Reprise,
10 minutes ago, NooBxUthpal said:
I just unplug all of the USB device,even I disconnect the front panel USB connector from the mobo. Only CPU and RAM are on mobo. But still the same.😓😓
Then sadly it needs repair. If repair cost is not feasible then go for a new board. H510 boards are pretty cheap and most budget boards can run a i3-10100
Motherboard:Asus prime H-510
Recently I'm into a problem with my PC.
While I'm trying to turn on my PC ,it's says "USB device over current status detected "
And the system shutdown after 15 second.
I've follow some YouTube tutorials and apply them,but didn't work. I tried to open it with unplug of every USB devices,like keyboard,mouse,headphone.but it's remains same.
I thinks is a hardware problem,(I'm not sure)
Is this possible to fix at home,or should I go to a shop to repair the motherboard.
https://linustechtips.com/topic/1601357-usb-device-over-current-status-detected/
As you said that you disconnected all usb devices from the back of your motherboard, did you also remove the front panel usb 2.0 and 3.0 headers? Sometimes they can get shorted because of age and oxidation.
Also remove everything attached to the motherboard like the drives and also reset CMOS by removing the CR2032 battery cell and reinserting it after a min or two.
If then also it gives the same warning then sadly the motherboard needs repair/replacement.
CPU: Ryzen 7 5700X Undervolted  Motherboard: B550 Aorus Elite V2 Rev1.2 RAM: G.Skill TridentZ Neo 3600Mhz CL16 32gb
GPU: MSI Mech 2X RX6600 8GB Cooler: ProLab Design AI360 LC AIO Storage: WD SN770 500gb + Sn550 1Tb + MX500 1Tb + 1TB HDD
PSU: Antec EAG Pro 750 80+G Case: Deepcool CG580 WH Monitor: Benq Mobiuz EX2510 144Hz
Mouse: G Pro Wireless Keyboard: Corsair K68 RGB Cherry MX Red Speakers: Creative Pebble V2
THIS.
I've had no less than three Asus boards do this in the past and all three had to be replaced (RMA).
BTW one was less than a month old when it happened.
This problem is more common with Asus boards than you'd think.
Yours may or may not still be under warranty but if it is, that's what I'd do.
If not you'll simply have to replace it.
"If you ever need anything please don't hesitate to ask someone else first"..... Nirvana
"Whadda ya mean I ain't kind? Just not your kind"..... Megadeth
Speaking of things being "All Inclusive", Hell itself is too.
5 minutes ago, Beerzerker said:
THIS.
Out of warranty maybe. I replaced it once before.
