Hi there ill be using a Lian Li O11 Vision case, along with Lian Li Galahad II Trinity 360 AIO and 5 deepcool fans (run out of budget to get lian li fans, had to use my old ones for now)
Will be cooling a 9800x3d and a 4070 ti super/4080 super/5070 ti depending on stock and current prices
From what i understand, please correct me if im wrong, this is the correct fan placement:
AIO (3 fans) intake with the tubes down on the right of the case , 3 fans exhaust on the bottom and 2 fans intake on the back
https://linustechtips.com/topic/1600692-best-fan-orientation/
Hot air rises rather than falling and cold air stays down
Ideally you want the AIO as intake, exhaust should be up and on the back and intake on the bottom and dedicated space next to the motherboard for AIOs or intake fans
TL DR put the AIO as intake next to the motherboardhere it a designated area, a fan or 2 on the bottom  as intake and the rest as exhausts up and in the rear of the case
You want either neutral or positive pressure so either the same intake and exhaust number of fans or more intake
I edit my posts for so if you saw a typo.... no you didn't, you are just crazy
https://linustechtips.com/topic/1600692-best-fan-orientation/#findComment-16649160
