Hi guys, iam planning to build my first pc. I just wanted to see if I did my research correctly or maybe iam doing something stupid.
I live in Lithuania and sometimes I cant get specific parts or some of the prices are bonkers.
I have pretty everything what I need listen down below. Please appraise my build and if you have any suggestions please let me know if they fit my budget.
Thank you for your help.
Budget (including currency): 1200 EUR
Country: Lithuania
Games, programs or workloads that it will be used for: Some triple A, maybe a little bit of 3d modeling
Other details
GPU - RX 7700 XT - 433eur
CPU - RYZEN 5 7600 - 178eur
CPU COOLER - Deepcool AK400 - 40eur
MOTHERBOARD - Asrock B650M PRO RS - 141eur
RAM - Kingston 32GB 6000MT/s DDR5 CL30 DIMM FURY Beast Black - 111eur
SSD - WD Blue SN580 - 62eur
CASE - Deepcool CH370 - 58eur
POWER SUPPLY - Thermaltake Smart BM3 750 W - 86eur
EXTRA FANS - Arctic P12 120 mm PWM [2x] - 11eur
~1120 EUR
https://linustechtips.com/topic/1600451-planned-first-pc-build/
Better PSU 100%. The thermaltake BM smart series is garbage. Get a corsair RMe, an MSI A750GL, a coolermaster mwe gold v2 or a thermaltake GT or GF A3/GF3 (i'll sneackilly throw in the Gigabyte ud750gm as well in that list)
Ideally a case with a lil better airflow from the front panel but that is a nitpick
Another nitpick would be the cooler and if you can find it for the same or less I'd get the peerless assassin 120 or the arctic freezer 36
I edit my posts for so if you saw a typo.... no you didn't, you are just crazy
https://linustechtips.com/topic/1600451-planned-first-pc-build/#findComment-16647405
Thanks for the reply and suggestions.
Regarding the cpu cooler. I saw in gamernexus videos that arctic freezer 36 is better for intel cpus rather than amd's thats why i skipped it
https://linustechtips.com/topic/1600451-planned-first-pc-build/#findComment-16647413
Uuuuh what?
A good cooler is just a good cooler and I believe you are mistaken with the fact the mentioned that they give a frame for intel not that they work better on intel
https://linustechtips.com/topic/1600451-planned-first-pc-build/#findComment-16647429
33 minutes ago, Why_Me said:
17 minutes ago, Millios said:
Uuuuh what?
Thanks guys for the info 🙂 appreciate it
https://linustechtips.com/topic/1600451-planned-first-pc-build/#findComment-16647435
7800xt or used 6800xt/6950xt
Aliexpress 8400f or 7700 depending in if you want to cut cost or get a better chip
Overpriced crap get a phantom spirit 120 ag620 frozn a620 etc.
Awful pricing on a 60€ unit at best, look for an 850w with a 10 year warranty like the msi a850gl pcie5 thermaltake gf a3 etc.
1 hour ago, Millios said:
corsair RMe
Fyi usually overpriced crap, only 7 year warranty and fan noise issues (search rme fan noise if you want proof), pricing is usually higher than the aformentioned 10 year warranty psus so yeah not a psu id reccomend unless its somehow the cheapest option available and by a decent margin (20€ or so) which i have seen once or twice before so yeah not a unit id reccomend
https://linustechtips.com/topic/1600451-planned-first-pc-build/#findComment-16647462
Alright I still mentioned quite a few alternatives that are the same price or cheaper.
See my Friend?
https://linustechtips.com/topic/1600451-planned-first-pc-build/#findComment-16647469
See my Friend?
Below ud1000gm is only 5 year warranty and mwe is also 5 year warranty but oh well theyre decent units by virtue of not having fan noise issues and being decently priced just that usually the 10 year warranty units arent much more so unless they are overpriced then theres usually no reason not to go for a 10 year warranty unit anyways
https://linustechtips.com/topic/1600451-planned-first-pc-build/#findComment-16647473
I am a "bit" desensitized to fan noise, virtue of having 300-400 euro pre built that's nearly a decade old so I subconsciously say "can't be worse than my cooler that sounds like a lawn mower taking off"
Other than that the warranty can be a valid factor so I see where you are coming from
https://linustechtips.com/topic/1600451-planned-first-pc-build/#findComment-16647477
I actually prefer being able to hear my pc though ofc not at full blast cause i have a server fan strapped on to a 120mm tower
So yeah not only desensitized but also prefers the noise it gives off at lower settings and since i dont have the thing to judge for myself i can just look at reports from others
rme fan noise issues are a widely known issue looking at the numerous threads that have been made on it so its not just a one off issue
https://linustechtips.com/topic/1600451-planned-first-pc-build/#findComment-16647830
