different chip sets work?
Solved by okkee,
9 minutes ago, Mark25 said:Can you replace a xeon cpu with a i7 cpu the mother bored is chipset C256 LGA 1200
According to this Intel page, only these Xeons are compatible with the chipset: https://www.intel.com/content/www/us/en/products/sku/213682/intel-c256-chipset/compatible.html
So probably won't work. You can still try out if you wan't though.
