Hello, friends! I have a choice to make which turns out to be harder than expected. I have a pc which is built 9 years ago. Currently i am trying to upgrade it and since i don't have the enough budget to go for a mb/cpu/ram combination i want to take it step by step. The motherboard is asrock z97 with the lga 1150 socket with i7-4790 on it. The gpu that i am currently using is gtx 960. I want to upgrade the gpu to achieve a little bit better overall performance in games. I looked up some second hand gpu's and the ones fitting in my budget are 1070ti and 1660 and anything below that. The problem is that i used some kind of bottleneck calculator and with those two specific gpu's i will get around 25% bottleneck from the cpu. Can you give me some advice about which gpu should i use, could be something else, even AMD to pair the cpu and gpu with pretty much no bottleneck but still better performance.
https://linustechtips.com/topic/1597764-upgrading-my-system/
Hi buddy,
While a bottleneck calculator can be useful, it really comes down to what works for you. Do you have a small list of games that you intend on playing and what kind of frame rate are you looking to achieve? Chances are someone here will have a working system with a similar spec and might be able to give you an idea of what you can expect in a 'real-world' example.
I would also say that the bottleneck calculators don't factor in every scenario.
A 1080ti for example is still a tasty GPU and while might struggle with newer AAA titles, can still chomp through frames at 1080p and even 1440p (I have one paired with a 6700k) and it still works for me in certain games without issue.
The bottleneck that most people are concerned about is when pushing higher frame rates at lower resolutions as this is where a lower powered CPU tends to struggle. You can usually overcome this (or at least minimise the bottleneck) but increasing the resolution and or in-game graphics settings so you are closer to being GPU limited.
While you are likely to get a load of different opinions on this (all will be very valid), I tend to 'brute-force' a system into submission and am more than happy to whack in GPU that's maybe more powerful than would normally be intended for with regards to the rest of the platform.
I do this fairly frequently given I tend to shell out on the latets Nvidia GPU every 2 years BUT only bother upgrading my core platform every 4 or so years.
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
https://linustechtips.com/topic/1597764-upgrading-my-system/#findComment-16633266
"Bottleneck" is a boogeyman of a word too often feared and used. There will always be a bottleneck. There are system out there that are a bottleneck for a 4090 and some where the 4090 is the bottleneck.
GTX 960 is old. Get something like a used RX5700XT. They should be cheap enough to not ruin your wallet and give you enough breathing room to push graphical prettyness even if FPS might be held back.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1597764-upgrading-my-system/#findComment-16633289
First advice: ignore this bottleneck "calculator" BS. From what you said, the way you go about upgradind is simple, just dump all the cash onto a better GPU.
As to which, your first order of business is putting your 960 for sale to get a couple extra bucks. It's not going to be much, but it'll make a big difference, so unless you plan to reuse it somewhere else, start by getting rid of your current card. With that done, hunt for a used Rtx 3060 or 3060ti; ignore the 10xx series, they are too old to recommend, and avoid the 16xx / 20xx ones if you can. Alternatively, an Rx 7600 would work well, but I doubt you'll find it for as good a price as a 3060/3060ti.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/1597764-upgrading-my-system/#findComment-16633322
