Hello all im glad to be here.
I picked these parts for a pc. Not sure if everything is compatible, if the ram is supported. When ram says kingston beast 2400 cl11 4x4, i can oc it to 2400 or it comes at 2400 from factory.
Then another thing is, willthe case fit everything?
Im not gonna buy a gpu now cause il get a 780ti for my birthday later, so the 4600 integrated hd will run league of legends well for me till then.
Also will the 780ti fit the case? I really love the look of this case. Is it a good case though?
And if you have any other opinions im open to advice.
This costs roughly 850euros in romania i can go max. Il let you guys choose a psu for me.
Here is the build i made:
RAM Kingston Beast Series DDR3, 4x4GB, 2400MHz, CL11cod:[ KHX24C11T3K4/16X ]
MOTHERBOARD ASUS MAXIMUS VI HERO, Intel Z87, LGA 1150
DAEMON 6004
http://www.evomag.ro/COMPONENTE-PC-Carcase/Game-Daemon-Carcasa-Game-Daemon-6004-108821.html
SSD Samsung 840 Evo Basic, 120GB, SATA III 600 (Stand Alone)
And for the processor its a 4770k.
Sorry im posting from the phone had to copy components.
https://linustechtips.com/topic/159765-help-in-building-a-pc/
??? Where is you link or pc components O.o
https://linustechtips.com/topic/159765-help-in-building-a-pc/#findComment-2128239
Beat me by a second. GG.
https://linustechtips.com/topic/159765-help-in-building-a-pc/#findComment-2128241
Everything is there i think.
Use Z97
Use CL 9 1600/1866 RAM
I recommend getting an aftermarket cooler because you'll be able to OC with that Mobo and CPU, so why not get it
What about HDD O.o
Also, if you can, try to go with 250Gb SSD
As for the case, i don't know... It's a mid tower so i think it should...
P.S. I like the case, it looks sick :D
EDIT: It also depends on what 780ti you'll get... Because every version has different length!
https://linustechtips.com/topic/159765-help-in-building-a-pc/#findComment-2128280
Thats all? What psu should i get, answer all my questions please
Sorry, i overlooked that... Btw, you should use the quote button if you want us to answer, because we get notification when it's used...
For that build i'd personally go with 550W 80+Bronze
But if you plan on SLI, then you should go with 850W 80+Bronze or 750 80+Gold
https://linustechtips.com/topic/159765-help-in-building-a-pc/#findComment-2128838
And with the ram, like i get 2400 from factory or i can go 2400 in oc
https://linustechtips.com/topic/159765-help-in-building-a-pc/#findComment-2128971
As far as i know, if it says "Kingston Beast 2400 Cl 11" then it's 2400 stock, it would be pretty stupid from manufacturers putting OC possible values in the name.
But like i said, 2400 is unneeded, but if you can find it for the same price as 1600/1866, and your Mobo supports it (Maximus VI Hero does support 2400 RAM), but it's still overkill...
https://linustechtips.com/topic/159765-help-in-building-a-pc/#findComment-2129020
