Hey guys long time reader, first time poster.
I am building a PC for my daughter, but I am finding it difficult to find Pink PC components. So, I am thinking of investing into ARGB for her PC.
Can I replace the fans on my Noctua with fans that have ARGB?
If not, what other cooler options are there?
Lastly, is it worth doing ARGB if I'm just trying to increase the amount of Pink her PC incorporates?
Thank you
https://linustechtips.com/topic/1596419-replace-cooler-fans/
Thank you
If you are just going to replace the fans, skip getting the noctua, the value is largely in the fans. I'd go for a more budget end cooler if swapping fans. Thermalright is a good base to start from. They even have some ARGB coolers so no need to swap fans at all.
https://linustechtips.com/topic/1596419-replace-cooler-fans/#findComment-16623885
Phantom spirit 120 ARGB is a good one, great cooler, 2 rgb fans and the fans' rgb itself is very bright and good quality
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1596419-replace-cooler-fans/#findComment-16624037
