MOBO won't post
Go to solution Solved by heliusm,
I resolved this issue. It involved re-flashing the vrm controller and changing the tdc, please look here for more information https://forums.servethehome.com/index.php?threads/vrm-modify-icc_max-to-run-high-tdc-oem-cpu.38686/
Hello, I just installed a Xeon 8259CL into a Tyan S5630GMRE-CGN mobo. Originally tried with 6 sticks of 32gb 2rx4 Sk Hynix. I reseated it a couple times, inspected the pins and the cpu, both looked fine. I tried again with one stick of ram and it did not post either. CPU_ERROR LED : (CAT_LED1) comes on. In the IPMI, no cpu is detected with a sensor error of IERR but it shows core voltages. BIOS rev: V7.215.B80
Please refresh before you reply because I edit my posts.
______________________________________________________________________________________________________________________
I am human and I do make mistakes. I'm not responsible for any damages or losses caused by the content I share.
My Laptop: MBP 14in 2023 M2 Pro
My Server: Tyan GT86C w/ 24 core Intel Xeon Platinum 8259CL; 196gb of SKhinex ECC DDR4; 768gb Optane DCPMM; Kioxia CD6-Rs and WD HC530s
https://linustechtips.com/topic/1596263-mobo-wont-post/
https://linustechtips.com/topic/1596263-mobo-wont-post/#findComment-16626880
