5 hours ago, XNederX said:
The problem was the water cooling that i was using
the pump wasn't good enough
i changed it and very thing is going well 😉
thank you for your help
Yeah, overheating will definitely cause freezing and lagging lol!
Having a high clock at low overall load percentage is normal. Modern processors will typically dynamically boost one or two threads, if it has the thermal headroom to do so, even during low load scenarios just to make your PC even snappier. Like, it's the difference between a program taking one second vs. two seconds to open. It might make a small difference but it all adds up in terms of just how snappy your PC feels.
(In fact it's common to see modern processors running higher clocks during light/moderate load than full load, where they usually have to pull clocks back in order to stay within safe power and thermal limits.)
"TV Gaming" PC: Ryzen 5 5600 :: 32GB DDR4-3200 :: RTX 2070 Super :: 500GB PCIe 3.0 SSD :: 1.5TB of SATA SSDs :: Windows 11
"Desk Gaming" PC: i5-4690K :: 16GB DDR3-1600 :: RX 560D 4GB :: 500GB SATA SSD :: Linux Mint 22
Office PC: Dell Pro 14 :: Ultra 7 268V :: 32GB DDR5-8533 :: 512GB PCIe 4.0 NVMe :: 6TB HDD :: Windows 11
Laptop: Dell Latitude 15.6" :: i5-4200U :: 8GB DDR3-1600 :: 500GB SATA SSD :: Linux Mint 22
Primary NAS: i5-7500 :: 16GB DDR4-2133 :: 250GB SSD :: 8TB HDD :: TrueNAS Scale 24.10
Web Server/Backup NAS: Raspberry Pi 4 Model B :: 2GB RAM :: 64GB microSD card :: 8TB HDD :: Raspberry Pi OS
Other tech stuff: iPad Pro M4 13" :: Samsung Galaxy A15 4GB :: 2022 Kindle Fire HD 7 :: PS4 Slim w/ 1TB SSD :: OG Nintendo Switch
https://linustechtips.com/topic/1595332-need-help/#findComment-16623455
