1 minute ago, doctabear said:
I haven’t tried the iGPU. And the other card is a 2070 super
Being an older card, the 2070 may be more permissive with the PCIe bus speed.
In the BIOS, can you change the PCIe speed to  Gen4 or Gen3 ?
Also, be sure to fully update Windows before installing AMD drivers for your 7800xt
https://linustechtips.com/topic/1594347-pc-not-displaying/#findComment-16609968
I changed it to gen4. Still didn’t work.
https://linustechtips.com/topic/1594347-pc-not-displaying/#findComment-16609983
I forgot to ask. Did you reinstall Windows since you upgraded your GPU ?
I know it is a hassle but I recommend installing a fresh Windows when switching major components like GPU and CPU.
Good luck !
https://linustechtips.com/topic/1594347-pc-not-displaying/#findComment-16610004
