My 5700x3d isn’t performing nearly to spec its thermals are fine but I’m not getting as much fps in games or points in Cinebench r23 if someone could help me it would be greatly appreciated (my mobo is a asus rog crosshair VIII wifi x570) if that helps any tips would be great
https://linustechtips.com/topic/1594223-cpu-help/
6 minutes ago, imagine not using arch said:
Is the CPU new or has this happened when it was used already?
Just installed it in the system last night and acted like that since the board is fine and the 3950x I had in it before runs about 10 fps better than the 5700x3d in cyberpunk
https://linustechtips.com/topic/1594223-cpu-help/#findComment-16609059
27 minutes ago, NotGonnaLook said:
There most definitely should not be a fall in performance due to your upgrade..
Assuming the freshly installed graphics card is not faulty and all current stable drivers installed?
The graphics card is fine and confirmed working since I just upgraded
https://linustechtips.com/topic/1594223-cpu-help/#findComment-16609077
On 12/28/2024 at 8:41 PM, FroZen said:
I’ll try that and see if
On 12/28/2024 at 8:02 PM, Renegade042 said:
And off course you did a clean windows install?
(clean install = format C: - not install over top of an old windows)
yup that worked thank you!
https://linustechtips.com/topic/1594223-cpu-help/#findComment-16611249
