Advice on a prebuilt
Go to solution Solved by PDifolco,
8 minutes ago, Fireord36 said:
Budget (including currency): $1350
Country: USA
Games, programs or workloads that it will be used for: Fortnite, random RPG, Roblox etc
just need PC
My friend is trying to get a PC and I've been trying to convince him to build it himself or have me build it but he doesn't want to so he wants to get a prebuilt. I was thinking ABS but he wanted NZXT(https://nzxt.com/product/player-two)and he is dead set on it so I need something a lot better because even though I'm not the best with prebuilt IK NZXT does not have the best price to performance. I also don't know if the pcs below are the best for the price but from a quick look they look decent especially because they are on sale.
https://www.newegg.com/p/N82E16883360528?Item=N82E16883360528&cm_sp=product-new version
https://newegg.com/p/N82E16883360528?Item=N82E16883360528&cm_sp=product-new version
The NZXT prebuilt isn't bad with the discounted $1400 price, sure performance will only be on par with the Newegg's $1200 prebuilts, but the NZXT has 3 clear advantages
- Looks way better...
- Good cooling
- Upgradability of AM5
Otoh the Newegg PC has a crappy stock cooler, that'll prevent drop in CPU upgrade, if ever the board can stand any.. and it's anyway limited to dead 13th/14th gen
As your friend don't need that much performance (he plays super light games), the NZXT PC is pretty cool ! 🙂
Country: USA
just need PC
https://linustechtips.com/topic/1594036-advice-on-a-prebuilt/
Country: USA
just need PC
- Good cooling
https://linustechtips.com/topic/1594036-advice-on-a-prebuilt/#findComment-16607819
yea not the first brand id think of when looking for a prebuilt
https://pcpartpicker.com/list/jXJqRV
9700x + 7900xt + 32gb 6000c36
yeah as you can see it gets completely wiped especially if you hav access to microcenter but if there isnt one then the 9700x becomes a 7700 and thats about it and heck i even used an nzxt case so the aesthetic will be quite similar too though 7900xt is pretty meh value considering the 7900xtx is 800$ and outperforms the 4080
looking around for other prebuilts though yeah seems like the ones you linked are the only decent options available, the 14400f build wins by a landslide due to not having a garbage ram config thatll nuke cpu performance so id reccomend that over the nzxt
a reference for diy vs buy performance wise
https://linustechtips.com/topic/1594036-advice-on-a-prebuilt/#findComment-16607888
like I said he is against me or him building it and likely doesn't wanna go through the hastle with Micro center building it because he wants the NZXTY build
https://linustechtips.com/topic/1594036-advice-on-a-prebuilt/#findComment-16607939
