Guys help I have my cpu cooler fan plugged in my dled port and my fan controller with the pc fans plugged in in another dled argb port (one is at the bottom left and one at the top right, and i also did both of them in one port with a splitter). When i turn on motherboard sync only the cpu cooler can change colour and my pc fans just turn white, and not letting me disable motherboard sync. I checked all the ports and replugged power cables.my motherboard is an asrock b460m pro4 and the software i used was the asrock polychrome but this also happens in other software like signal rgb
CPU: I5 10400F GPU: EVGA RTX 2060 KO ULTRA
https://linustechtips.com/topic/1593729-pc-fans-problem-help/
