Budget (including currency): 1200euro
Country: Lithuania
Games, programs or workloads that it will be used for: Games like Rust, Cs2, Fortnite,mount and blade 2 Bannerlord
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I want a new pc, probably with Radeon 5700x3D CPU and RX 7700 XT 12 GB GPU (not sure), looking to buy from a site in upcoming days : ITWORK.LT , and i want to have 240+ Hz
Please someone help if possible
https://linustechtips.com/topic/1592771-new-pc-build-help/
Country: Lithuania
Also, the cpu cooler might be too big, but 1 fan in the cpu cooler will be more than enough instead of two if the ram won't fit with the cooler. My friend has amazing temps with this cooler and only 1 fan inside it.
https://linustechtips.com/topic/1592771-new-pc-build-help/#findComment-16599725
Country: Lithuania
Add a case and storage.
https://www.kaina24.lt/p/pagrindine-plokste-gigabyte-b550-aorus-elite-v2/
Gigabyte B550 Aorus Elite V2 €128.47
https://www.kaina24.lt/p/amd-ryzen-7-5700x3d
AMD Ryzen 7 5700X3D €195.12
https://www.kaina24.lt/search?q=deepcool+ag500
Deepcool AG500 CPU Cooler €43.14
https://www.kaina24.lt/p/g-skill-ripjaws-v-f4-3600c18d-32gvk-cl18-32gb-ddr4-3600-mhz-udimm-2x16gb/
G.Skill Ripjaws V DDR4-3600 32GB (2x16GB) CL18 €60.88
https://www.kaina24.lt/p/gigabyte-radeon-rx-7700-xt-oc-12gb-ddr6/
Gigabyte Radeon RX 7700 XT OC 12G €443.80
https://www.kaina24.lt/p/maitinimo-blokas-msi-mag-a750bn-pcie5-750-w/
MSI MAG A750BN PCIE5 750W ATX Power Supply €79.56
Total: €950.97
https://linustechtips.com/topic/1592771-new-pc-build-help/#findComment-16599865
