Budget (including currency): Not relavant
Country: US
Games, programs or workloads that it will be used for: Gaming, school work, minor editing
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): https://pcpartpicker.com/list/qpJhyW
Will these parts be compatible? My Samsung 860 EVO Solid State Drive M.2 seemed to be incompatible with the motherboard chosen, and after some searching, I found the adapter to fix that issue. Will the adapter work, or do I need to adjust my build?
Edit: New Link is posted!
https://linustechtips.com/topic/1590743-thoughts-on-final-build/
"This part list is private."
current PC:
PC configs I used before:
Just now, Azriel said:
The new link is posted. So sorry!
Yeah looks good, is it already bought?
current PC:
8 minutes ago, Azriel said:
Not yet. I really wanted to hold out for the new line of AMD GPUs coming out, but I won't be able to unfortunately. What were your thoughts?
Yeah looks great,
this RAM's in stock:
https://pcpartpicker.com/product/PzRwrH/silicon-power-xpower-zenith-rgb-gaming-64-gb-2-x-32-gb-ddr5-6000-cl30-memory-su064gxlwu60afdfsk
you don't need paste if you're buying new cooler, they usually come with at least enough paste for first use.
For adapter, not really sure, though seems simple enough. Your Samsung is SATA M.2 with 2 notches, so yeah, likely.
current PC:
1 minute ago, podkall said:
Yeah looks great,
Thank you for suggesting some RAM at a lower price! The paste on the part list and a few other items are from a modified part list of my old PC. I didn't bother to remove them but simply set them to purchased/$0.00.
