Budget (including currency): 1800 AUD
Country: Australia
Games, programs or workloads that it will be used for: RPG(), FPS(valorant, cs), want to try out AAAs, photoshopping as well
Other details:
GPU: GALAX/MSI GeForce RTX 4070 SUPER 1-Click OC 2X 12GB GDDR6X 887 AUD
CPU: AMD Ryzen 5 7600 250 AUD
Motherboard: MSI B650M GAMING PLUS WiFi Micro-ATX 197 AUD
SSD: MSI SPATIUM M371 NVMe M.2 SSD 1TB 71 AUD
RAM: Corsair Vengeance RGB RS 32GB (2x16GB) D4-3200 CL16 116AUD
AIO: GAMEMAX IceBurg 360 Digital BK Liquid Cooler 108 AUD
POWER SUPPLY: Thermalright TG 650 650W 80 Plus Gold Fully-Modular PSU TR-TG650 87 AUD
CASE: darkFlash DS900M M-ATX PC Case BLACK 85 AUD
*concerned if the power supply is enough for not... please comment on the validity of this builds
Thanks guys!!!!
https://linustechtips.com/topic/1590194-first-pc-please-help/
Country: Australia
Other details:
Thanks guys!!!!
Welcome to the Forum!
This is a great looking list and will do very well!  Its fairly balanced too 🙂 I like it! There are however things I would change.
The 650w is plenty enough for this system.   You could in theory run it on a solid 500w.  No problem here.
I am not a fan of the Thermalright TG 650w,  there are few or non reviews on this and very little information in general so I can't recommend it.
I would buy the MSI MAG A750GL, its a bit more expensive but leaves room for some great upgrades later and it has a 7 year warranty as well.
The RAM is wrong as you have listed DDR4 memory.  This motherboard and CPU requires DDR5 memory.  We recommend DDR5 6000Mhz CL30/32 as this is the sweetspot for Ryzen 7000.
The Ryzen 7600 comes with a stock cooler that is more than plenty so spending 108 AUD on a AIO is a waste of money.  I would spend that money on something else, maybe on a few games for your new awesome gaming machine!  ( Or that power supply upgrade )
If you want a some RGB and a beefier cooler I would recommend the ''Thermalright Peerless Assassin 120 SE ARGB'' but again you don't actually need a CPU cooler as the CPU comes with one.
https://linustechtips.com/topic/1590194-first-pc-please-help/#findComment-16581695
Hi thanks for the massive help!!! I also have a question regarding the ram, would you recommend corsair ram or T force rams 🙇‍♂️ Im completely new to buying components, would you think im getting ripped off from these prices?
https://linustechtips.com/topic/1590194-first-pc-please-help/#findComment-16582349
No Problem!  🙂
The prices seem fair for Australia, I see nothing wrong here.
''Corsair vengeance'' and  ''Team Group T-Force Delta''  are very popular and they are both respectable brands.
G.Skill is also a reputable RAM brand.
https://au.pcpartpicker.com/product/x4VmP6/gskill-ripjaws-s5-32-gb-2-x-16-gb-ddr5-6000-cl30-memory-f5-6000j3040f16gx2-rs5k
https://linustechtips.com/topic/1590194-first-pc-please-help/#findComment-16582417
