Help.
Go to solution Solved by Needfuldoer,
What hardware do you have? Please list all your components, either in a post here or link to a PCPartPicker list.
If we don't know what hardware you have, all we can do is guess and make general suggestions.
Make sure you have your 8-pin CPU power cable connected.
Does your motherboard need a BIOS update to work with your processor?
So...pc will not work.i built this pc obout a year ago,sunce then it has been one huge headache.the issue is that the pc will turn on and then nothing it just keeps spining fans in a wierd way and the cpu and dram light Keep bliniking in sequence.i have changed the motherboard,changed ram and powersupply.and still i have the same problem.took it to a technician.he says its a motherboard problem.ok so i buy a THIRD motherboard . come back home with pc and Boom,same fking problem.at this point this is my last resort ,either i get help here or im burring it.
PS if i got any spelling mistakes wrong sry its not my first language.
Part list is:
Intel i3 13100f
Gpu radeon rx580 8gb
Motherboard:gygabyte b760m ds3h ddr4
Ram kingston 16gb 3200mz
Powersuply master cooler 750m
Ssd 1 terabyte
https://linustechtips.com/topic/1589991-help/
https://linustechtips.com/topic/1589991-help/#findComment-16580308
