So I am going to be adding a couple of 140mm case fans to my H440 to improve airflow. I'm trying to decide which fans to get and any suggestions would be grateful. I'm currently trying to decide between the Noctua NF-A14 and the Corsair AF-140's. The corsair ones are cheaper and will match my color scheme better, but the Noctua's are quieter. Which one do you guys think are better?
"You can try to play chess with a pigeon. But even if you win, it'll shit on the board and strut around."
https://linustechtips.com/topic/158972-case-fan-suggestions/
Noctua NF-A14 FLX or the ULN variant. Both great fans, not the prettiest, but I love them. Silent and powerful!
I have the FLX and it come with two adapters for 7 and 5V, so you can even make it quieter, but still maintain a great deal of performance.
Also, I really like the Noctua color scheme, kinda says: "I opt for performance, not looks!"  :D
I have one AF-140, not built in anymore. Switched to the Noctua named above.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
https://linustechtips.com/topic/158972-case-fan-suggestions/#findComment-2118226
Also, would you suggest 2x140mm fans in the top for exhaust or 3x120mm?
2 140s
https://linustechtips.com/topic/158972-case-fan-suggestions/#findComment-2118228
3 120s is more than 2 140s=3x120=360 but 2x140=280
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/158972-case-fan-suggestions/#findComment-2118231
Noctua fans are the way to go, high static pressure, and relatively low noise... If you don't like the price of Noctua fans, look around on the web for some fans with high static pressure.
Ok thanks. Looks like I'm gonna go with the Noctua fans.
https://linustechtips.com/topic/158972-case-fan-suggestions/#findComment-2118260
Have a look at noiseblocker aswell, them and gentle typhoons are direct competitors.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/158972-case-fan-suggestions/#findComment-2120366
