Budget (including currency): 414USD (35000 INR)
Country: India
Games, programs or workloads that it will be used for: Adobe Lightroom, Beam ng, and mid range games
Other details
Build plan-
AMD Ryzen 5 5600G - 151.28 USD (12780 INR)
MSI MPG B550 - 155 USD (13139 INR)
MSI MAG A650N 80 Plus bronze - 56 USD (4799)
Corsair Vengeance Lpx 16GB (16×1) 3200MHz - 34 USD (2889 INR)
I already have a case (MSI 320R), storage, fans and peripherals.
I'm currently using a Lenovo ThinkCentre M82 SFF (i5-3550) with a GT 710 and a 75hz 1080p monitor and a second cheap monitor.
I selected the 5600G because of the 3.9 GHz base clock speed. I checked some versions below that and above that and none were in my price range.
I will get a RX6600 in a few months for around 236 USD (20000 INR).
Should I change something?
Did I miss something?
Any help is appreciated!
Thanks.
Sorry for any mistakes it's my first time posting on a fourm.
Edited by krasinski
https://linustechtips.com/topic/1589133-build-help/
If you can save to the full budget, can get a much better system instead of gaming on the iGPU for a few months.
Using a budget of $650 USD
PCPartPicker Part List: https://pcpartpicker.com/list/PTdK8Q
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($124.00 @ Amazon)
Motherboard: Gigabyte A520M K V2 Micro ATX AM4 Motherboard  ($88.98 @ Amazon)
Memory: TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  ($48.99 @ Amazon)
Video Card: PowerColor Fighter Radeon RX 6750 XT 12 GB Video Card  ($299.99 @ Amazon)
Case: MSI MAG FORGE 320R AIRFLOW ATX Mid Tower Case  (Purchased For $0.00)
Power Supply: EVGA 650BP 650 W 80+ Bronze Certified ATX Power Supply  ($54.99 @ Walmart)
Total: $616.95
Generated by PCPartPicker 2024-11-16 22:24 EST-0500
And if you can wait a bit longer still, an extra $60USD will get you to the 5700X3D, also needs a cooler as it doesn't come with one.
PCPartPicker Part List: https://pcpartpicker.com/list/2pZ6h7
CPU: AMD Ryzen 7 5700X3D 3 GHz 8-Core Processor  ($199.00 @ Amazon)
CPU Cooler: Thermalright Assassin Spirit 120 EVO DARK 70.4 CFM CPU Cooler  ($19.86 @ Newegg Sellers)
Total: $711.81
Generated by PCPartPicker 2024-11-16 22:26 EST-0500
https://linustechtips.com/topic/1589133-build-help/#findComment-16574523
Total: $616.95
Total: $711.81
I can't wait, but if increase my budget a little I can go for the AM5 platform,
AMD Ryzen 5 7600 - 215 USD
MSI Pro B650M-B - 102 USD
Adata XPG 6000MHz 16GB×1 - 55 USD
MSI MAG A650BN 650W 80 Plus  bronze - 56 USD
 Total = 428 USD
I'm okay not to play games for a couple of months. I can't buy the GPU at the same time.
https://linustechtips.com/topic/1589133-build-help/#findComment-16574664
