I bought a graphics card for my New PC, but it isn't displaying anything, I've bought another cable, I reseated the GPU, I've checked the monitor and cables, but nothing. I have the cable plugged into the GPU itself BTW.
By the way, I have Linux as my OS, because my old GPU didn't support Windows, new one is RTX 4060.
Also, the white VGA light comes up on my mobo...
https://linustechtips.com/topic/1588794-problem-with-gpu/
Welcome to the Forums! Reseating the bios is always a great start.
Make sure to mark solutions, as it helps us find people who need help faster. Thanks!
I am human and am therefore prone to error, so I apologize if I make mistakes and I hope you understand.
Have a Nice Day!
https://linustechtips.com/topic/1588794-problem-with-gpu/#findComment-16571696
Do you mean resetting the bios? I update it when I built it last week.
I literally can't see anything so I can't see the bios. Cpu doesn't have iGPU
https://linustechtips.com/topic/1588794-problem-with-gpu/#findComment-16571712
No, sorry about that. I meant the cmos battery. It should reset the bios and potentially fix issues. image.jpeg.55d784a3f0e071219903d74255437b91.jpeg
Have a Nice Day!
https://linustechtips.com/topic/1588794-problem-with-gpu/#findComment-16571741
