So i have build my first pc. I played a roblox game with my friend and suddenly its crashed and freezing then it quits without i pressing alt+f4 or close. Then on 5 sec its goes bsod and saying i dont remember what the problem but its keep bsod and i cant get automatic repair till my motherboard got old bios screen boot and its turn and off repeatly without and dosent show on screen anymore. please help my dad will really mad with me for wasting this thing and its broke.
https://linustechtips.com/topic/1588522-please-help/
Have you tried resetting the BIOS? (Unplug your PC from the wall, remove the coin cell battery from the mobo, wait 10-20 seconds and reinstall the battery)
English is not my first language, so please excuse any confusion or misunderstandings on my end, also I like to edit my posts a lot.
F@H-Stats
The Rigs:
Xenon:
CPU: 2x Xeon E5 2690 V3
RAM: 64GB DDR4 2133 RDIMM
MoBo: Supermicro X10DRi-T4+
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
RAM: 48GB DDR4 3200 UDIMM
MoBo: ASRock B550M Pro4
The Laptop (Lenovo Legion 5 15IAH7):
CPU: Core i5 12500H
RAM: 16GB (2x8GB) DDR5-4800
GPU: RTX 3050 Ti mobile
OS: Windows 11 Home
The Tablet:
Dell Latitude 7212 Rugged Extreme Tablet (Core i5 8350U/8GB RAM)
OS: Windows 11 Pro
https://linustechtips.com/topic/1588522-please-help/#findComment-16569617
I already tried to switched new cmos battery and its turn on and my uefi bios not load only show uefi bios bar logo and its turn off and its turning on repeatly i tried to switch ram, unplug my hdd and ssd i really dont want switch for new thing or get somone repair wihout my parent knowing
https://linustechtips.com/topic/1588522-please-help/#findComment-16569626
I'm kind of confused by what you first said but to clarify you were playing a roblox game it crashed and froze and now your PC wont last longer then 5 seconds without  bsoding.  there's a big list of things it could be, If you can figure out what the error code is exactly then it'll be a lot more clear what's wrong. The things I can think of the top of my head would be your CPU overheating, broken ram (try only using one stick on the furthest left slot ) or your CPUs integrated graphics messing with your GPU. I have no clue what your PC specs are so please forgive me if i'm completely wrong.
https://linustechtips.com/topic/1588522-please-help/#findComment-16569677
So um. Sorry my english is so bad. I will try to speak properly if i can. Ur method i didnt try yet. I only use to taking the cmos battery out and leave it like 20 minutes. I already try to unplug the gpu and ram but didnt try yet to put one ram stick on first slot.
Here my spec btw.
I7-3770 basic non unlocked
Gigabyte z77p-d3 ATX
16gb ram ddr3
Asus gtx 750ti 2gb
128 gb ssd adata
1tb 7200k wd blue
Cooler master ex2treme 500w
https://linustechtips.com/topic/1588522-please-help/#findComment-16569690
8 hours ago, Tridefender said:
If a bsod that requires repair instead of just a simple rebooting, i presume windows boot files damaged. You would need to create a recovery usb.
Yes at this point i know my windows corrupted. But when i turned on my pc its keep turning on and off and no post to monitor somehow my motherboard bios boot turn into old one before i updated it.
https://linustechtips.com/topic/1588522-please-help/#findComment-16570134
42 minutes ago, Salad09 said:
Probably my ssd broke ?
I wouldn't say that, windows is notorious for such accidents. Perhaps a small part of your SSd broke, or some software accidentally deleted something?
But I suggest you to reinstall Windows or use a Windows PE to salvage some data first.
https://linustechtips.com/topic/1588522-please-help/#findComment-16570171
Idk but could be my ssd problem at this point. But heres the vid : https://streamable.com/hmpmgc
https://linustechtips.com/topic/1588522-please-help/#findComment-16570310
