Hi all,
I spent some times to enquire on reddit tech and IT channels in vain and hope to find experts here to get a definitive answer to the question:
Considering that temperature decrease when the air density decrease, why can't we use a partial void/vacuum in a PC to chill its components?!
While heat won't be dissipated by air molecules, the general ambient temperature should chill the hardware and prevent it to get warm no?
Please neglect the capacity of the hardware to sustain a partial vacuum and imagine capacitors are super tough 🙂
Please share your views!
https://linustechtips.com/topic/1587822-pc-innovation-cooling/
Wdym? Let's take space as example, space is a void, according to you it should be -285 degrees Celsius. Then why space ships and nuclear batteries needs heatsinks?
Btw, vacuum actually prevents heat dissipation, that's the purpose of double layer glass windows.
https://linustechtips.com/topic/1587822-pc-innovation-cooling/#findComment-16563869
Can't see how vacuum could prevent heat to build up when the components work, stars do heat up (and quite a lot)  for example
Then a totally "airproof" case won't be able to dissipate any heat , and the whole thing will explode/implode and burn 😮
https://linustechtips.com/topic/1587822-pc-innovation-cooling/#findComment-16563883
2 hours ago, Nooblynoob said:
Hi all,
You're applying a concept backward.
No because vacuum is an insulator. Like double pane glass windows.
You want greater density to take more heat away, actually.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1587822-pc-innovation-cooling/#findComment-16563952
  • 2 weeks later...
Temperature decreases when pressure is decreased relative to its starting temp, rate of decrease in pressure, and ambient temp, all other factors being constant. This is due to the decrease in gas molecules bumping into each other. So the heat we are measuring is the energy within that volume of air.
But with a cpu, we have a heat generating component present that is actively adding heat to the system. We need a way to extract that heat and energy away from its origin.
You can radiate the heat, but very inefficient way to move the heat.
You can conduct it away into another medium like using a heatsink.
Or you can convect it away by using a flow of another medium over the hot component, such as air or water.
If you suck out the air there is no medium to transfer the heat to. Hence you would be in effect insulating the part as the radiation heat is ineffective at this level (for various reasons).
So air or water as convection
 Take your pick
https://linustechtips.com/topic/1587822-pc-innovation-cooling/#findComment-16571234
What i assume youre trying to describe is a drop in pressure causing things to cool down, for example, a can of compressed air or deodorant getting cooler as is decompresses and there is a drop in pressure.
The issue is doing this multiple times while the system isnt starved of a heat transfer media. The thing is we have already solved this. They repeatedly compress and expand liquid to cool or heat it, know as a heat pump, youll find these in refridgerators or A/C units. So the best bet is probably to put an A/C in your room to help cool your pc
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1587822-pc-innovation-cooling/#findComment-16571354
On 11/13/2024 at 4:08 AM, Spring1898 said:
Lol! Best line of the day!
ya thats the best but hot air and cooling can be confusing. you can cool something with hot air just not as good as cool air and well speed would play a factor in that. moving air is better then no moving air even thow its hot...
https://linustechtips.com/topic/1587822-pc-innovation-cooling/#findComment-16573813
