Hi! I have an AM5 build, 7800X3d, 4080s, Gigabyte aorus elite ax ice, 2x16gb 6000 cl30 expo ram, corsair rm1000e.
I'm currently facing an issue where the PC boots most of the time from a cold boot, but if I restart it, it almost never boots back till I restart multiple times. I first thought expo is causing this as it was working fine with expo disabled, but this also happened to default settings in BIOS.
Order of things:
Restart PC -> BIOS Splash (Aorus loading) -> Loading gets stuck -> I hear windows loading and RGB in my PC getting set to the profiles -> screen goes black -> no Display signal.
I have to restart multiple times till it boots.
Also my expo 1 profile uses SoC 1.4v (its a preset so I assume its ok) Things I've tried:
  1. Setting SoC to 1.15 to 1.25
  2. Reseating CPU, GPU, RAM
  3. Looseing cooler up a bit
  4. Multiple Nvidia drivers
  5. Different BIOS, currently on latest F32e
And the only solution that works Setting my PCIex16 slot to forcibly run at Gen3. This has booted everytime, instantly.
Solutions, Ideas?
GPU RMA done, they said it's all good.
Planning to get Motherboard RMA done.
Thanks!
https://linustechtips.com/topic/1587717-need-help-troubleshooting-boot-issue/
Order of things:
Solutions, Ideas?
Thanks!
Latest motherboard Bios? Latest GPU bios/firmware? Latest monitor firmware (if it's upgradable)?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Order of things:
Solutions, Ideas?
Thanks!
bootlooping also may be caused by a powerspike tripping your powersupply
try different powerline\boot with one stick ram and all mics stuff disconnected (even gpu if its possible)
Did, funny thing when I connect both motherboard and gpu video outputs, when it boots correctly it boots through GPU, when it fails ot boots through motherboard.
It worked fine for a week, then I rma'd the GPU tomorrow I'm sending the Board. 🙃
3 hours ago, buzz4tw said:
Yes, all latest
GPU power plugged in all the way?
Which manufacturer of the 4080S, perhaps Gigabyte?
13 hours ago, buzz4tw said:
Yes, plugged in all the way.
Gigabyte Aero
Check the area near the PCI-E slot on the card, both sides, look for hair thin fractures.
I suspected it was a Gigabyte card but I still hope it's not what I think the issue might be.
  • 3 weeks later...
I ended up switching the motherboard to an AsRock Steel Legend. Fixed my issues. I don't understand what happened to the other board.
On 11/4/2024 at 2:26 PM, lazarestas said:
i meant what is your powersupply model? if it is not capabple to handle your pc power needs, it can just trip every time
RM1000e, but anyway I ended up getting an as rock b650 steel legend. Fixed the issues, the gigabyte mobo rma said it was ok but I ended up asking for a refund. Found too many posts with similar issues and gigabyte 😕
