Hi guys,
I just got a Gigabyte R9 290 (Windforce Edition) and the temps I've been seeing seem a bit high. It's idling in the low 40s and hitting high 80s under full load (85 max on 15 min 1080p Furmark.) I was wondering if anyone with this card has seen similar numbers, since the benchmarks seem to indicate it should be running about 10 degrees cooler both at idle and under load. I know 290s run hot, but I'd expected better numbers from Windforce, since my 7870 maxed out at about 65 degrees under full load. Should I be worried?
Thanks
https://linustechtips.com/topic/158750-r9-290-temps/
I would say yes, but the 290 and 290x run hot and the only way of really solving that issue is by doing water-cooling and the temps will be more around what your 7870 had for temps.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/158750-r9-290-temps/#findComment-2115522
completely normal for a 290
Specs
https://linustechtips.com/topic/158750-r9-290-temps/#findComment-2115525
Those cards run hot on any cooling.  High 80's is pushing it a little. Try to optimize your case's airflow, increase fan speeds a little if you have to.  You could even try lowering the ambient temperature by getting an AC or some fans.
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
https://linustechtips.com/topic/158750-r9-290-temps/#findComment-2115543
Crank up the fans. I did that on my reference 290 and I'm down to 75 at full load with ~67% fan speed.
CPU: Intel i7 4770k w/Noctua NH-D15, Motherboard: Gigabyte Z97 Ultra Durable, RAM: Patriot 8Gb 1600Mhz (2x4Gb), GPU: MSI R9 390x Gaming,
SSD: Samsung 840 EVO 1Tb, HDD: Caviar Black 1Tb, Seagate 4Tb Hybrid, Case: Fractal Design Define R4, PSU: Antec Earthwatts 750w
Phone: LG G2 32Gb Black (Verizon) Laptop: Fujitsu Lifebook E754 w/ 1TB Samsung 840 Evo SSD Vehicle: 2012 Nissan Xterra named Rocky
https://linustechtips.com/topic/158750-r9-290-temps/#findComment-2115877
