Audio gets interrupted when pc under load
Solved by Ennio187.POG,
10 minutes ago, Tridefender said:Would you please try with the audio jack/bluetooth on the mobo? Perhaps it's the dongle's problem.
thank you for your help but it seems that the issue has magicly resolved. Have you tried turning it off and on haha. i have been listening.
Thanks again.
and sorry for wasting your time
