Good argb + fan controller?
Go to solution Solved by PDifolco,
8 minutes ago, MiszS said:
I meant like the physical hub where you plug all the cables in
Ok my bad thought about sofware lol
As for a fan/RGB hub I use this, rather cheap and works as intended
I chose this over noname Chinese stuff at 10 bucks for peace of mind 🙂
46 minutes ago, MiszS said:
Can someone recommend a good ARGB + PWM fan controller? I need it to have at least 6 of each port and to be not too expensive like some corsair ones I saw
I use Fancontrol for PWM fans, it's really wonderful, and SIgnalRGB (free version) for RGB, it's ok
SignalRGB offers fan speed control on paid versions I think, but I didn't try it, FanControl is too good
I had a look at OpenRGB but it's pretty barebones
  • 2 months later...
ok.. so this will probably do the same thing? https://www.asus.com/motherboards-components/cooling/tuf-gaming/tuf-gaming-argb-pwm-fan-hub/
I have 3 Antec P12 ARGB fans (https://www.antec.com/product/cooling/p12-argb) connected to a hub and I would like to be able to manage them individually.
I have enough PWM ports on the motherboard but only one Gen 2. Can anyone recommend a good controller? Even just a way to daisy chain them to the same port.
