Preconfig vs build kit
Go to solution Solved by Why_Me,
1 hour ago, markspizman said:
Budget (including currency): $1500-$2000
Country: USA
Games, programs or workloads that it will be used for: Halo, Call of Duty, old Xbox games, general surfing and streaming netflix, etc
Other details I want to build myself, but not knowledgeable on parts. I've replaced phone batteries and electrical outlets. I thought it would be safe to use a build kit so everything is compatible. Cost wise I'd prefer the pro, but would do the elite if the overall quality/cost ratio is better. I am not doing a new monitor for now and using old keyboard and mouse unless kit comes with it. I currently have an HP Pavilion Desktop 570-p020 with i5-7400 and 8GB ram. Would appreciate thoughts on using kit vs some preconfig.
                          Cosair Pro Build Kit $1749.99                                       Corsair Elite Build Kit$2099.99
case:                           Cosair 4000D Airflow                                          same
processor:                  i5-14600k                                                             i7-14700k
GPU:                           NVIDIA RTX4070                                                  NVIDIA RTX4070Ti
Memory:                    Corsair 16GB Vengence RGB DDR4-3200          Corsair 32GB Vengence RGB DDR4-3200
Storage:                     Corsair 1TB M.2 NVMe SSD                                 same
Motherboard:             B760-P wifi DDR4                                                same
Power:                        Corsair 650w PSU                                                Corsair 750w PSU
Cooling:                     Corsair H100i elite RGB Liquid CPU                    same
toolkit:                         yes        yes
You will be the CoD god .. threw in a 180hz IPS gaming monitor ^^
PCPartPicker Part List
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($476.74 @ Newegg)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler  ($29.99 @ Amazon)
Motherboard: *MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  ($169.99 @ Amazon)
Memory: *TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($88.99 @ Amazon)
Storage: *MSI SPATIUM M482 Eco-Pack 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($99.99 @ MSI)
Video Card: *Gigabyte WINDFORCE OC GeForce RTX 4070 Ti SUPER 16 GB Video Card  ($799.97 @ Newegg)
Case: *Montech AIR 903 BASE ATX Mid Tower Case  ($65.00 @ B&H)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($83.79 @ Newegg)
Monitor: *MSI G272QPF E2 27.0" 2560 x 1440 180 Hz Monitor  ($164.99 @ Amazon)
Total: $1979.45
Generated by PCPartPicker 2024-10-26 18:51 EDT-0400
Country: USA
toolkit:                         yes        yes
https://linustechtips.com/topic/1586919-preconfig-vs-build-kit/
Country: USA
toolkit:                         yes        yes
Are those GPU's Supers or regular?
For $2100, that build kit is LACK.  ING.
You can build your own, as IMO.... a build kit is basically doing it yourself.    Watch a few guides on YT, and you'll be more than fine.  Plus you have all of us to help with any questions or concerns.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1586919-preconfig-vs-build-kit/#findComment-16556362
9 minutes ago, markspizman said:
Those are regular not super. I'm just worried about creating an unbalanced build. To much cpu or gpu and not enough power or cooling.
Oh well that's perfect, since this is the place for us to figure that out.
With your budget, you have a lot of options.
For example, even the high priced 7800X3D and top end 7900XTX are in your budget.  Now, maybe should you wait for the 9800X3D reveal, probably.  If you prefer Nvidia, the 4080Super can be squeezed in with a little less CPU.
It's a couple moving sliders, but as long as you don't go any less than Ryzen 7600 or Intel 14600K, with a 7900XT / 7900XTX / 4070Ti Super / 4080 Super... you're really in good shape.
4K or 1440p Ultra machine...
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($476.74 @ Amazon)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  ($38.90 @ Amazon)
Motherboard: Gigabyte B650 GAMING X AX V2 ATX AM5 Motherboard  ($169.99 @ Amazon)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($99.99 @ Amazon)
Storage: TEAMGROUP MP44L 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($107.99 @ Amazon)
Video Card: XFX Speedster MERC 310 Black Edition Radeon RX 7900 XTX 24 GB Video Card  ($869.99 @ Best Buy)
Case: Fractal Design North ATX Mid Tower Case  ($119.99 @ B&H)
Power Supply: Super Flower Leadex Platinum 850 W 80+ Platinum Certified Fully Modular ATX Power Supply  ($101.48 @ Newegg)
Total: $1985.07
Generated by PCPartPicker 2024-10-26 17:13 EDT-0400
That's just 1 option/pairing.  Are you playing in 1440p?  4K? 1080p?  We can adjust back down to your $1500 budget as well...
1440p Ultra/High machine...
CPU: AMD Ryzen 5 7600X 4.7 GHz 6-Core Processor  ($199.99 @ Amazon)
Video Card: ASRock Challenger OC Radeon RX 7900 GRE 16 GB Video Card  ($529.99 @ Newegg)
Total: $1368.32
Generated by PCPartPicker 2024-10-26 17:17 EDT-0400
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1586919-preconfig-vs-build-kit/#findComment-16556374
Thank you for the help!
Glad to!  Others will chime in as well, giving you more info hopefullly.
My signature black has my current builds, so you can see I put my money where my mouth is.
But you can build yours easily, if you want to save the "build fee" they are charging you.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1586919-preconfig-vs-build-kit/#findComment-16556400
Really depends on use case and perhaps graphics settings.
CPU: *AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor  ($271.18 @ Amazon)
CPU Cooler: *Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  ($169.99 @ Amazon)
Memory: *TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($85.99 @ Amazon)
Case: *Lian Li LANCOOL 215 ATX Mid Tower Case  ($81.99 @ Adorama)
Total: $1724.51
Generated by PCPartPicker 2024-10-26 18:47 EDT-0400
  • If 1080p, then I'd look for 9800x3D perhaps, or 7800x3D but of course mind that it's price is inflated.
current PC:
PC configs I used before:
https://linustechtips.com/topic/1586919-preconfig-vs-build-kit/#findComment-16556453
Country: USA
toolkit:                         yes        yes
Total: $1979.45
https://linustechtips.com/topic/1586919-preconfig-vs-build-kit/#findComment-16556455
Thank you to Dedayog, podkall and Why_Me. The list from Why_Me looks good to me, especially since it has the least compatibility "disclaimers". Assuming that means anything. I am holding off on a monitor and using my old HP "24 or "27". I recently cancelled DirecTV and if I stick with streaming may get a nice monitor for watching that(and possibly a hemorrhoid cushion if I sit in my desk chair that much). Next step ordering and buying windows 11. I already use norton security so can add the new build to it. Thank you again to all of you!
https://linustechtips.com/topic/1586919-preconfig-vs-build-kit/#findComment-16556765
