Boot drive problem
Solved by C2dan88,
2 hours ago, Dilen futch said:not sure what I am doing wrong
There appears to be two partitions on the drive with data. If you want to wipe the drive and install windows fresh - delete the two existing partitions first so you get an unallocated option.
Otherwise you will need to resize partition 2 so another partition can be created to install windows to it.
