Budget (including currency): Around £4500
Country: United Kingdom
Games, programs or workloads that it will be used for: AAA Gaming (inc Flight Sim), Music Production, Penetration Testing
Hi all,
I'm planning to build one of two machines in the next couple of months. As my workplace is contributing to part of the budget, I’ve decided to invest a bit more with the hope of future-proofing the system for several years (I know, I’m probably kidding myself!). I’m considering either a full ATX build or a more compact M-ITX build. Below are my current thoughts and component choices. I would appreciate any feedback, particularly if you foresee any potential issues or have suggestions for better components.
ATX Build:
  • Case: Fractal Design Torrent Black RGB Light Tint Windowed PC Gaming Case
  • Motherboard: Gigabyte AMD X670E AORUS MASTER
  • CPU: AMD Ryzen 9 7950X3D
  • CPU Cooler: Corsair iCUE H150i RGB ELITE 360mm Intel/AMD CPU Liquid Cooler
  • RAM: Corsair DOMINATOR Titanium RGB Black 64GB 6400MHz DDR5 Memory Kit
  • GPU: Gigabyte NVIDIA GeForce RTX 4090 24GB WINDFORCE V2 Ada Lovelace Graphics Card
  • PSU: Seasonic Prime TX1000
  • Monitor: ASUS 48" 4K Ultra HD 138Hz G-SYNC Compatible OLED HDR Gaming Monitor
M-ITX Build:
  • Case: Cooler Master NR200P V2 MAX Mini-ITX Tower SFF PC Case with 280mm AIO Cooler & 850W Gold PSU
  • Motherboard: Gigabyte AMD B650I AORUS ULTRA Mini-ITX Motherboard
Storage: This will be transferred from my current machine; compatibility has already been verified.
I should note that I’m not opposed to an Intel CPU. I’ve also been considering the 14900KF as an option. Although I’ve always been an Intel user, I’m curious to see what AMD has to offer.
Any help or advice you can provide will of course be greatly appreciated!
| Corsair 750D Airflow Edition | Intel I7 8700K | Gigabyte Aorus Gaming 7 | CMK32GX4M2B3000C15
| EVGA GTX 1080 Ti SC2 | 750w Seasonic Focus Gold | NZXT Kraken X62
| 980 Pro 1TB M.2 | 970 Evo 250GB M.2 | 860 QVO 1TB SSD | 850 Evo 500GB SSD | Synology DS920+
| Alienware AW3418DW | Creative Soundblaster Z | Creative Katana | Sennheiser HD 6XX
| Logitech MX Master 3 | Roccat Vulcan Aimo | Official Microsoft Xbox Controller
| Xbox Series X | Xbox One | PS4 Pro
https://linustechtips.com/topic/1583692-future-gamingwork-build-help/
Will the system(s) be replaced before the extended warranty (5 years) on K CPUs expires?
Penetration Testing
What does this involve, I mean, in terms of CPU/GPU/RAM demands?
Does anything that you do use AVX512?
Are you are aware that: X3D CPUs are not very sensitive to memory speed and 64GB 6400 may not work "out of the box" with an AM5 CPU?
To be fair I'm not sure, although I doubt it. Given the money that is being put into this, I'll be looking to keep it going as long as is realistically possible.
There will likely be high demands on both CPU & GPU due to doing password cracking/hash cracking as well as programming.
Honestly, this is the first I've heard of it. I've had a quick scout about through Google and I don't believe so.
I was not aware of this, but I can lower the memory speed if required. Will likely save a bit of cash! 😉
In that case, I'd be very reluctant to buy an Intel 13th-14th gen CPU.
The problems might be fixed by the microcode updates, but we still don't know if there will be any consequences long-term and if you can safely expect these CPUs to last 10+ years like previous CPUs have.
If you can do some more research I'd recommend it, because in some workloads that are optimised for it the 9900X/9950X smash the 7000 series and Intel 14th gen CPUs. Phoronix have some benchmarks that might be relevant to you here. Though, there would be trade offs with the gaming performance if you switched.
If you can read up a bit on OC forums it might help you get updated on what current CPUs are capable of (since Ryzen's IMCs will have improved over time, they certainly did with AM4), but yeah, most kits above 6000 are optimised for Intel & use XMP rather than AMD & use EXPO.
32GB sticks are dual rank which adds to the load on the memory controller. AMD's specs say you should hit 5600 with a 9000 or 5200 with a 7000 CPU, though they also suggested low latency 6000 was optimal for the 7000 series CPUs which is technically beyond their official spec.
