Ncase m1 video card help
Solved by Excon,
Yeah that what I'm concerned about I looked up builds from other people and i haven't been able to see anyone use a windforce card and the builds I see it looks very tight. I just wanted to see if I could get any confirmation.
Think of it this way. Look for builds with watercooled GPUs the side for fittings is probably even a bit wider than the Windforce tag
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
Posted in New Builds and Planning9
