I'd check my emails, see if there are any from Epic (e.g. initial signup). That should tell you which email address was used to sign up. That could potentially be used to recover the username and/or password. Otherwise, try talking to their support. But without irrefutable proof of ownership, it's extremely unlikely they are going to help in any way.
mail id which the epic account was created is accessible. but now epic says no such gmail exists when try to login with that gmail
had some otp few months ago which was read
Contact their support with receipts when you/they bought/redeemed the games on Epic from your email. That'll prove that account existed at some point.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
If you try too often, that could trigger a security mechanism that prevents further logins from you IP for some time. Best course of action is to contact their support and provide whatever info they ask for.
