ive got a list of displays but dont know which one is the best one, can you help me please. If you suggest any others please let me know.
https://www.amazon.co.uk/MSI-MAG-274QRF-QD-E2/dp/B0CPQ59G1H/ref=sr_1_3?crid=EJQG6HOIABGT&dib=eyJ2IjoiMSJ9.jnu8O4lJRarV4o3MzvOplPkxvTUKfkC_IOaU38EClSEh35grs_yVtZmJl7-zJd_cnEZ5ioRWcAkm9TCD2Yzvqg__zAgu8HZ5KswB-gw8bQad19VE9wg9J431_glLedTKRmnXuLsVTVwEulUInnfMp-MNQjwAvfawOfMtF7r_Vu2Sxkb7uGteoS5gJq7FeHA8NkSjn9PkYq-lMBaTF-V8iIwEi7X4CxfMBzVSXE76Xzw.lLChtvFZo8TWeTwKuGUrULJth-5hxM2TArlpDRV4Hx0&dib_tag=se&keywords=msi%2B1440p&qid=1725274813&sprefix=msi%2B1440p%2Caps%2C112&sr=8-3&th=1
https://www.amazon.co.uk/MSI-G272QPF-E2-Gaming-Monitor/dp/B0CPQ7D6QJ/ref=sr_1_7_sspa?crid=EJQG6HOIABGT&dib=eyJ2IjoiMSJ9.jnu8O4lJRarV4o3MzvOplPkxvTUKfkC_IOaU38EClSEh35grs_yVtZmJl7-zJd_cnEZ5ioRWcAkm9TCD2Yzvqg__zAgu8HZ5KswB-gw8bQad19VE9wg9J431_glLedTKRmnXuLsVTVwEulUInnfMp-MNQjwAvfawOfMtF7r_Vu2Sxkb7uGteoS5gJq7FeHA8NkSjn9PkYq-lMBaTF-V8iIwEi7X4CxfMBzVSXE76Xzw.lLChtvFZo8TWeTwKuGUrULJth-5hxM2TArlpDRV4Hx0&dib_tag=se&keywords=msi%2B1440p&qid=1725274813&sprefix=msi%2B1440p%2Caps%2C112&sr=8-7-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9tdGY&th=1
https://www.amazon.co.uk/LG-UltraGear-27GP850P-B-FreeSync-Displayport/dp/B0CPGLZL1G/ref=sr_1_4?crid=18GSSHN7BJK9E&dib=eyJ2IjoiMSJ9.izaegJy3DsU9oygfDCmShFI2zj4pJay6MjPrzfAoVqmTKaARuDaoLusCDSAlgVnzrGBcDXk2qvqX2UL1B7mxLtMYl0ynptfbI1siWw7X-xMEgCrIc35DYOTy999cX1QA-fYNG9g8CLpSyV5KLDzIiTtW6hJhhXU4WiKtn9_ynMVTFvGf6afrhCB5mCFMm_hIdwBpMLybIauThsRSmlacXmHHEtd5maY-pWGlMIGDXT8J9cqKz-bCpoGOu8aXRkAwyeJcPiipmEDAUK4fEjbxizZlSGT5ewNmVtjcBafACWg.mvJ2BmpCiVz0fyTo3MPlzbRyjr2aCGMlRluH5uKj094&dib_tag=se&keywords=lg%2Bultragear%2B1440p&qid=1725274912&s=computers&sprefix=lg%2Bultragear%2B1440p%2Ccomputers%2C113&sr=1-4&th=1
https://linustechtips.com/topic/1581473-help-choosing-display/
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1581473-help-choosing-display/#findComment-16509591
What are the requirements for the Monitor?
Low latency for gaming? Color accuracy for creative works? HDR?
current PC:
PC configs I used before:
https://linustechtips.com/topic/1581473-help-choosing-display/#findComment-16509614
1 hour ago, JakubR8 said:
colour accuracy mainly but its also going to be used for gaming.
you don't need crazy color accuracy for gaming, because it's expensive,
either way, if you copy the code numbers of Monitor, you can look for reviews of the monitor,
easiest way is to find out if the monitor has review on RTINGS website,
for example, I was able to find the MSI's older version,
your options have MAG 274QRF QD E2, I found Optix MAG274QRF-QD (it's missing the E2 which could mean whatever but most importantly these monitors should be quite similar)
I also from, this list:
21 hours ago, venomtail said:
I was able to find RTINGS review on 90% monitors that have review on pcpartpicker,
one or two monitors had proper YouTube review instead of RTINGS review that still used sensors,
feel free to go through that list,
and it's as simple as doing this:
pasting it in google and writing review behind it:
finding something that goes deep:
and then ruling it out immediately in terms of gaming performance because of these 2 values:
I found these 2 to have decent stats on the reviews, but feel free to check out other reviews of other monitors you find:
https://www.rtings.com/monitor/reviews/gigabyte/m27q-x
https://www.rtings.com/monitor/reviews/msi/optix-mag274qrf-qd
This is Gigabyte M27Q X max response time at Balanced overdrive setting:
  • Notice how Gigabyte's worst 10% First/Total response times, are as fast as ASUS's Average response time
If you have further questions let me know.
current PC:
https://linustechtips.com/topic/1581473-help-choosing-display/#findComment-16510172
