case fans
Go to solution Solved by Poinkachu,
4 hours ago, Comedy2Gamer_official said:
Hello I recently purchased a deepcool CC360 ARGB case and have tried and failed at multiple attempts of hooking up the fans I really have no clue as to what I am doing wrong I do not see a fan plug in the back or I am just not looking for the correct plug for it here is my exact mainboard https://www.newegg.com/gigabyte-b450m-ds3h-wifi-micro-atx-amd-b450-am4/p/N82E16813145164?Item=N82E16813145164
??? You plug fans to the motherboard
Those fan headers that comes with a PC case is just fan hubs.
An extension-slash-splitter basically.
No idea if that pc case of yours supposed to come with one or not
edit: I don't think it comes with fan hub, since they don't mention it in the manual
Your motherboard has only 2 fan headers. 1 is for CPU (cooler) fan, 2nd is the only system fan header
Marked with blue rectangle
If you need more fan header then just buy a powered fan hub, it's pretty cheap as long you don't buy fancy brand's one.
https://linustechtips.com/topic/1581370-case-fans/
Edited by Poinkachu
Refresh before you reply
https://linustechtips.com/topic/1581370-case-fans/#findComment-16508789
I guess the case came with directions didn't notice them until today but I read them and it told me to plug them into sys_fan they are working now but I am 100% going to have to order extensions since I have the main wires running across my AIO cpu block.
https://linustechtips.com/topic/1581370-case-fans/#findComment-16508967
