Looking at a system that has had motherboard & memory replaced.
On the gigabyte mb:
-only works with one stick, but it boots & works
-Second stick: nothing
on the MSI MB:
if only one ram stick is present. I get the press F1 to enter boot (if I reset the bios first using the jumper)
pressing F1 just blanks the screen: no bios access?
If I add the second stick it gives a dram & CPU error light.
-CPU is a is a ryzen 7700x.
-Gigabyte B650 aorus elite AX
- MSI b650 gaming  wifi
I had a hard time believing the cpu was the problem (hence the ram & MB replacement) I guess I ran out of options?
Is there anything I can try before I bite the bullet and order a new CPU? (or try and RMA it)
I tried every combo of memory sticks at this point (only one, 2, 2 nut in alternate slots etc..)
thx
Jo
https://linustechtips.com/topic/1581326-cpu-problem/
