Facing micro mouse stutters and frame drops. I know this is not a mouse issue, as I have already tried other mice and uninstalled and reinstalled mouse driver.
CPU: i7 8700
GPU: Rx 560
RAM: 16 GB DDR4
Facing micro stutters when working or browsing the web. The cursor freezes up momentarily and skips a frame or two sometimes. If I move the mouse around fast, the stutter is noticeable and I can see the cursor skip frames. The PC was working fine until I installed the graphics driver recently as I had to reinstall windows. Attaching a video for better understanding and tried to draw on paint but it just jumps to the next frame if it skips.
I have used DDU to uninstall AMD Adrenalin and just reinstalled the driver but the issue still persists. I clean installed windows 10 and the issue was still there, updated to Win11 23H2 still no luck. I tried booting into safe mode and the problem is NOT there, but it is in normal mode. The problem does not exist in games like Valorant as well. I tried disabling all startup apps but still no solution. I have used OCCT to check my parts for error and there were none. I am wondering if it could be because of any services. In safe mode there are about only 40 services running but on normal boot there are around 130.
https://linustechtips.com/topic/1580615-stutter-issues-driving-me-crazy/
