Steam Deck Issues Connecting 4 Controllers
UPDATE - MOSTLY Solved!
ISSUE #1: CONTROLLER ORDER - Unfortunately, it's not possible to disable the built in deck controller without some hacky linux commands. As such, the built in steam deck controller still always maps as controller #1 buuuuut the workaround is to change that controller to "Mouse Only" mode/profile in the steam controller settings. *This was especially an egregious game-breaking issue in Minecraft Dungeons, but with the workaround, as soon as a controller button is pressed, the game figures out that a controller is being used, and switches inputs.
ISSUE #2: DISCONNECTS - I've narrowed this issue down to 3 things.
#1 - My 8BitDo controllers and 2.4G USB dongles needed firmware updates.
https://support.8bitdo.com/firmware-updater.html
#2 - Steam Input is just not great for many of the cheapo indie party games that I'm trying to play. If you notice that your controllers are duplicated, or are switching between which players are controlled, or just not working at all IN game, try disabling steam input from the games setting/properties > Controller > Disable Steam Input. This got Horizon Chase Turbo and Rubber Bandits working much better for me.
#3 - If you have an 8bitdo ultimate controller that came with a charging cradle, plug the 2.4g dongle INTO the included charging cradle, and then plug the charging cradle into the steam deck dock. For some reason the cradle helps eliminate some USB3 oddity that causes the dongles to reset randomly or cause lag.
