Case fan configuration
Go to solution Solved by Dedayog,
16 minutes ago, 3llyas said:
So right now I have 3 120mm fans in the case 2 being in front as intake and one at the back for exhaust, I'm planning to add 2 140mm fans and replace the intake fans in front and move the 2 10mm fans to exhaust air at the top. Is this a good configuration?
My case is Tecware Nexus Air M2, so I think it has got a pretty good airflow. Is negative airflow bad and will it affect anything? I don't mind the dust as I will regularly clean the PC.
My PC spec is:
I5 12400
Zotaz RTX3070 Twin Edge
16Gb 3600Mts DDR4 RAM
MSI Pro B760M - A Wifi
ID Cooling SE 914 XT V2 ARGB
Yes, as 2x 140mm fans are roughly the same area as 3x 120mm ones.
Solid fan setup.
Just make sure the 2x 120's on top are as far back as possible and the 140's as low as reasonably possible, to provide the best wind tunnel effect.
So right now I have 3 120mm fans in the case 2 being in front as intake and one at the back for exhaust, I'm planning to add 2 140mm fans and replace the intake fans in front and move the 2 120mm fans to exhaust air at the top. Is this a good configuration?
My PC spec is:
I5 12400
https://linustechtips.com/topic/1578749-case-fan-configuration/
My PC spec is:
I5 12400
Solid fan setup.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1578749-case-fan-configuration/#findComment-16486503
Solid fan setup.
Thanks that's great to know. Wind tunnel meaning the air that gets sucked in front does not immediately exhausted is it?
https://linustechtips.com/topic/1578749-case-fan-configuration/#findComment-16486508
Yes, as cases are best with low front to upper rear air flow.  Unless you can get some fans under the case, of course.
Getting cool air in, and hot air out like a hair dryer.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1578749-case-fan-configuration/#findComment-16486557
The fan upgrade sounds good. If you're willing to keep your PC dust-free, then it doesn't matter if it's positive or negative pressure air flow. I have yet to see, hear or experience a compelling argument to the contrary. Us volunteers recommend positive because it's easier to care for the PC (in general).
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1578749-case-fan-configuration/#findComment-16486757
