First Gaming PC Build
Go to solution Solved by Hinjima,
10 minutes ago, Eazok said:
Budget (including currency): 1650€ - 1750€
Country: Germany
Games, programs or workloads that it will be used for: mainly Gaming (Valorant, Rainbow Six Siege, Newer Assassin's Creed games)
My current idea would be:
CPU: AMD Ryzen 9 7900X
CPU Cooler: Be quiet! Dark Rock Pro 5
Motherboard: Gigabyte B650 Eagle AX
Memory: Corsair Vengeance DDR5 32GB 6400MHz CL 32
Storage: 500GB Crucial P5 Plus (OS), 2TB Crucial P5 Plus with Heatsink
GPU: RTX 4060 Ti 16GB
Case: iCUE Link 3500X RGB
PSU: Corsair RM850x (850W)
https://de.pcpartpicker.com/list/jzQPPF
I want to use 2x 1440p 165Hz Monitors
Thanks in advance for any responses 🙂
https://de.pcpartpicker.com/list/MwDjmD
The Ryzen 7600X is just as fast as the 7900X in gaming performance but going from a 4060 Ti so a 4070 Ti Super or 4070 Ti will be a massive increase in performance 🙂
Country: Germany
https://linustechtips.com/topic/1578623-first-gaming-pc-build/
Country: Germany
https://linustechtips.com/topic/1578623-first-gaming-pc-build/#findComment-16485477
You want low profile RAM when using a dual tower cpu cooler so that said cooler isn't impeded by the RAM heatsinks. Look for a board with the newer 2.5G LAN seeing how it can be a plus for latency which is a good thing when killing your fellow Europeans in online shooter games. A single 2TB SSD will work just fine.
https://www.techpowerup.com/review/montech-air-903-max/
PCPartPicker Part List
CPU: *AMD Ryzen 5 7500F 3.7 GHz 6-Core OEM/Tray Processor  (€148.00 @ notebooksbilliger.de)
CPU Cooler: *Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (€54.89 @ Proshop)
Motherboard: *Asus TUF GAMING B650-PLUS ATX AM5 Motherboard  (€157.00 @ Computeruniverse)
Memory: *G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€115.90 @ Galaxus)
Storage: *TEAMGROUP MP44L 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€113.62 @ Galaxus)
Video Card: *Gigabyte WINDFORCE OC GeForce RTX 4070 Ti SUPER 16 GB Video Card  (€801.55 @ notebooksbilliger.de)
Case: *Montech AIR 903 MAX ATX Mid Tower Case  (€79.90 @ Alza)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€102.00 @ Amazon Deutschland)
Operating System: *Microsoft Windows 11 Home Retail - Download 64-bit  (€93.94 @ Computersalg)
Total: €1666.80
Generated by PCPartPicker 2024-08-05 23:34 CEST+0200
https://linustechtips.com/topic/1578623-first-gaming-pc-build/#findComment-16485609
