Low GPU Utilization
Solved by Hinjima,
14 minutes ago, Dot-_-Com said:NZXT Cam. In assassins creed Valhalla I get a her age 70 to 80fps Same with battlefield 2024
i play on a 1440p 165hz monitor
NZXT Cam is known to be very buggy and there is no way you are getting 70-80 fps with 1% GPU utilization.
From what your system specs is, 70-80 fps at 1440p high/ultra settings seems correct.
You can try MSI afterburner or Nvidia overlay to check GPU usage.
