I’ve had my card since like december and I’ve been dealing with a really dumb and small issue that happens like once a day.
I’ll be playing any game doesn’t matter and on discord with my homies just talking and the card will just like freeze for 3 seconds. Then all my audio inputs are resorted to default and I have to change them fast so I can hear friends again for callouts.
I have updated every driver I could find and I kinda was coping with it until I lost a ranked game because of it. I’ve tried sfc, dism, uninstalling nvidia drivers ect. Even thought it could be my cpu but I have found nothing to fix it at all. Tried going back to default clock speeds to but even before the overclock it did the same thing.
5950x
Msi 4080 Ventus OC edition
MotherB: Msi 570x edge max wifi
128gb G skill 3600 hz
1200w power supply
no over heating issues either on anything. Really hope someone has a fix because I have called nvidia, amd, and msi
nvidia was no help at all like so for real
amd said definitely graphics issue which i assumed
msi said most I can do is send it in and hope they can recreate the issue or to test on another of my pcs but none of them can run this card with the amount of power it needs
https://linustechtips.com/topic/1576952-4080-msi-ventus-issue/
Have to admit bit confused about what your GPU has to do with discord losing your mic and headphone connections.
CPU : Ryzen 7 7800X3D @ -30mv All core
CPU Cooler : Thermalright Frozen Prism 240mm AIO
Mobo : Asrock B650m Pro RS Wifi
Ram : 32GB (2X16GB) Lexar Ares 6000MHZ CL 28-36-36-68
GPU : MSI Gaming X Slim 4070Ti Super 16GB ( 308W PL +140 Core +1000 Memory )
Storage : 2TB Verbatim Vi5000 Gen 4 NVME
PSU : Thermalright TG-750w 80+ Gold ATX 3.0 PCIE 5.0
Case : Fractal Design Pop Mini MATX
Case Fans : 3 X Thermalright TL-C12C-S RGB
Monitor :27" Samsung Odyssey G5 2560 x 1440 180 HZ IPS
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
https://linustechtips.com/topic/1576952-4080-msi-ventus-issue/#findComment-16469641
16 hours ago, Tetras said:
What USB devices do you use for sound (e.g. headphones, microphones) and how are they connected to the PC? Do they have custom software?
When the issue occurs, is there any entries in the event viewer relevant to your problem?
I haven’t seen anything in event viewer gonna check next time to double check
My microphone is ran through nvidia broadcast to clear out background noise
and my headset uses razer synapse  via wireless usb
https://linustechtips.com/topic/1576952-4080-msi-ventus-issue/#findComment-16469894
17 hours ago, 8tg said:
Why do you think this is a graphical issue when your audio driver is breaking and returning to defaults?
I’m not the best person in terms of audio so tbh idk it’s just really odd it happens at the same time as when I get a graphical stutter
https://linustechtips.com/topic/1576952-4080-msi-ventus-issue/#findComment-16469916
Yeah but the graphical stutter could be your system locking up and not your GPU , it's not impossible it's your GPU but we don't know yet.
Can you check windows event viewer and see if it says anything in there?
https://linustechtips.com/topic/1576952-4080-msi-ventus-issue/#findComment-16470025
