PC replacement build
Go to solution Solved by Hellowpplz,
48 minutes ago, FidoG said:
Budget (including currency):  $1500 USD but flexible to spend more
Country: United States
Games, programs or workloads that it will be used for: Heavy VR use, Arma, Siege, Blender, Photoshop, Substance Painter, and other miscellaneous applications and games
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Im looking to upgrade(probably more or less just build a new one) from my current computer which is just hitting 5 years old with a Ryzen 9 3900x, Asus Mobo, 32gb DDR4 Ram, 650watt PSU, and a RTX 3070 TI with two 2TB M.2 Samsung 980 pro's and two more 2TB Samsung 870 EVO
Im wanting to Keep my Graphics card and my Storage drives but basically everything else NEW and im wanting to use the NZXT H9 Flow Case in a all white build. i also was thinking about AMD's new Ryzen 9000 series CPUs that i think i saw release at the end of this month. So i guess i really need help on decided Ram PSU and any CPU AIO recommendations if possible and if its known if you can use any already released mobo's with the new Ryzen Chips
PCPartPicker Part List: https://pcpartpicker.com/list/FHsCHG
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($384.99 @ Newegg)
CPU Cooler: ARCTIC Liquid Freezer III A-RGB 48.82 CFM Liquid CPU Cooler  ($177.63 @ Amazon)
Motherboard: Gigabyte B650 AORUS ELITE AX ICE ATX AM5 Motherboard  ($180.49 @ Newegg)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($99.99 @ Amazon)
Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($0.00) Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($0.00) Storage: Samsung 870 Evo 2 TB 2.5" Solid State Drive  ($0.00) Storage: Samsung 870 Evo 2 TB 2.5" Solid State Drive  ($0.00)
Video Card: NVIDIA Founders Edition GeForce RTX 3070 Ti 8 GB Video Card
Case: NZXT H9 Flow ATX Mid Tower Case  ($159.97 @ Amazon)
Power Supply: be quiet! Dark Power 13 1000 W 80+ Titanium Certified Fully Modular ATX Power Supply  ($239.90 @ Newegg)
Total: $1242.97
Generated by PCPartPicker 2024-07-17 23:09 EDT-0400
Shelled on the psu for future gpu upgrades if you would
IF i make the cooler more realistic and your willing to be flexible then heres one with a *huge gpu boost:
PCPartPicker Part List: https://pcpartpicker.com/list/tQYzQP
CPU Cooler: Thermalright Peerless Assassin 120 White 66.17 CFM CPU Cooler  ($39.90 @ Amazon)
Video Card: PowerColor Fighter OC Radeon RX 7900 GRE 16 GB Video Card  ($529.99 @ Newegg)
Total: $1635.23
Generated by PCPartPicker 2024-07-17 23:18 EDT-0400
*a lot of work related applications favor nvidia. Raw performance will still be enough to outrun this, but not enough to be worth it in my opinion. Games on the other hand.......
https://linustechtips.com/topic/1576898-pc-replacement-build/
CPU: *AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor  ($160.85 @ Amazon)
Total: $160.85
Generated by PCPartPicker 2024-07-17 23:04 EDT-0400
https://linustechtips.com/topic/1576898-pc-replacement-build/#findComment-16468770
Total: $1242.97
Total: $1635.23
I edit my messages more than not –
Probably some dude on the internet
https://linustechtips.com/topic/1576898-pc-replacement-build/#findComment-16468771
Total: $160.85
note: im so tired that I might as well be drunk so idk if you did this on purpose or not
https://linustechtips.com/topic/1576898-pc-replacement-build/#findComment-16468772
Is 5700X3D or 5800X3D + GPU/PSU upgrade not an option? What do you seek to accomplish with this upgrade? If you have $1500 or more to spend on a new build. I would just drop in a 5700X3D and a 7900 XT for now with a 750-850W Tier A or B PSU. Then wait and see what Zen 5 and new cards have to offer. AMD most likely won't have anything to replace the 7900 XT or XTX according to rumors. NVIDIA will of course be coming out swinging. And Intel should have an offering that tops out at like 4070 Super levels. By then we should also have a clear understanding of what Arrow Lake is like. But if your goal is better performance in games: a 3D V-Cache chip and GPU upgrade would make the biggest difference.
PCPartPicker Part List: https://pcpartpicker.com/list/dnrfQP
CPU: AMD Ryzen 7 5700X3D 3 GHz 8-Core Processor  ($182.99 @ Newegg)
Video Card: Sapphire PULSE Radeon RX 7900 XT 20 GB Video Card  ($659.99 @ Newegg)
Power Supply: Super Flower Leadex III Gold 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($79.99 @ Newegg Sellers)
Total: $922.97
Generated by PCPartPicker 2024-07-17 23:34 EDT-0400
https://linustechtips.com/topic/1576898-pc-replacement-build/#findComment-16468777
Total: $922.97
like i had said, my computer is old and starting to show its age, probably have close to 30k hours on it if not more, it gets heavy heavy use and am just having weird larger issues here and there an would like to just nix all the possible issues with new everything mostly. My graphics card isnt even a year old yet so thats the only reason im really keeping it and not upgrading yet
Also quick edit, im not having performance issues when playing games a small minor upgrade is not what i looking for
https://linustechtips.com/topic/1576898-pc-replacement-build/#findComment-16468787
Do you live near a Micro Center?
Also, you say you are having peculiar large issues that are popping up, but you are not having performance issues. Can you clarify on that? Sometimes a simple Windows reinstall fixes those random issues. If you are not having performance issues. I'm not sure what your goal is exactly. I understand you are a heavy user, and the machine has been put through its paces. But some troubleshooting wouldn't be bad either.
https://linustechtips.com/topic/1576898-pc-replacement-build/#findComment-16468806
CPU: *AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor  ($244.99 @ Amazon)
CPU Cooler: *Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: *MSI PRO B650-P WIFI ATX AM5 Motherboard  ($149.99 @ MSI)
Memory: *Silicon Power Value Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($84.97 @ Amazon)
Video Card: *Gigabyte EAGLE OC GeForce RTX 4070 Ti SUPER 16 GB Video Card  ($780.00 @ Newegg)
Case: *Montech AIR 903 BASE ATX Mid Tower Case  ($65.00 @ B&H)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Total: $1450.84
Generated by PCPartPicker 2024-07-18 03:04 EDT-0400
https://linustechtips.com/topic/1576898-pc-replacement-build/#findComment-16468839
Total: $1242.97
Total: $1635.23
Would you happen to have any other AIO recommendations I wouldn't have to wait over a month for?
https://linustechtips.com/topic/1576898-pc-replacement-build/#findComment-16469478
Lian Li Galahad II Performance 360
Not cheap or expensive (for a good aio), reliable from experience
https://linustechtips.com/topic/1576898-pc-replacement-build/#findComment-16469572
