Why is a normal 2x120mm tower coolers not an option?
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1576709-7600x-build-cooler/#findComment-16467214
11 minutes ago, patrikrk13 said:
i tought since it's prime day i could go for a 240 - 360 aio since they are between 50-70£ ( 65-90 )
I waint it to be cool enough
for example cooler master master liquit 360mm aio it's 56£
As long as it fits and looks nice to you, buy what you like. Most are safe and will work.
Avoid MSI MAG, they had gunk issues. I think recalled and solved now but still icky, wouldn't risk it.
https://linustechtips.com/topic/1576709-7600x-build-cooler/#findComment-16467222
3 hours ago, patrikrk13 said:
Since today there are alot of 240mm aio on sale
Cooler master master liquid 250mm core
Msi mag core liquid m250
Thermalight Frozen prism 240
Thermalight aqua elite v3
and many more
i dont know witch to pick
get a thermalright since they actually perform pretty well for the price looking at gamersnexus review for the frozen prism and theyre damn cheap probably undercutting even the meh performing masterliquid aios
and go for a 360mm while you are at it just for that added bling with extra cooling performance ontop of that
https://linustechtips.com/topic/1576709-7600x-build-cooler/#findComment-16467292
