GIGA AORUSBYTE B550I PRO AX (AM4 AMD/B550/Mini-Itx/Dual M.2/SATA 6Gb/s/USB 3.2 Gen 1/WiFi 6/2.5 GbE LAN/PCIe4.0/Realtek ALC1220-Vb/DisplayPort 1.4/2xHDMI 2.0B/RGB Fusion 2.0/DDR4/Gaming Motherboard) ,AMD Ryzen 7 5800X 8-core, 16-Thread Unlocked 4.7 GHz, TEAMGROUP T-Force Vulcan Z DDR4 32GB (2 x 16GB) 3200MHz (PC4 25600) Ram, EVGA GeForce RTX 3060 Ti XC Gaming, 08G-P5-3663-KL, 8GB GDDR6, Metal Backplate, LHR
https://linustechtips.com/topic/1576166-a-enclosure-for-my-odd/
8 minutes ago, Edward78 said:
So you're trying to adapt an internal DVD reader to USB?
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
https://linustechtips.com/topic/1576166-a-enclosure-for-my-odd/#findComment-16462684
Most tray-load USB optical drives are basically what you're looking for but pre-assembled.
If you're just trying to read CDs and DVDs, pick any drive in your budget. As far as I'm concerned, they're all interchangeable jellybean parts.
https://linustechtips.com/topic/1576166-a-enclosure-for-my-odd/#findComment-16462691
I am getting a new case with a ODD spot, ny CPU gets to lie 90c+ when I start games.
Quote
It would nice if software started coming on USB sticks. I think we still would like a pysical copy to buy from a store or estore. Amazon has Windows 11 flas drives why no other software?
https://linustechtips.com/topic/1576166-a-enclosure-for-my-odd/#findComment-16462694
