Hi!
I am looking for feedback on my PC list, this is my first PC build so I want to make sure everything is okay.
cpu
Intel Core i5-12400F
Cpu cooler
Cooler Master MasterLiquid 240L Core
motherboard
MSI PRO Z790-P WIFI
Ram
Kingston FURY Beast (1 x 32 GB)
Main storage
Crucial P3 Plus 500 GB
Extra storage
Seagate Barracuda XT 3 TB
Graphics card
Founders Edition 1080
Case
NZXT H510i
Power Supply
Corsair RM850x
I have already bought the CPU, the case, and do not want to upgrade GPU yet, but am looking at the 3080
I am happy with most of this, but am unsure about the CPU cooler, so any suggestions there would be useful.
Thank you in advance.
UPDATE
I have changed a few parts
cpu
Cpu cooler
Thermalright Frozen Prism ARGB
motherboard
MSI PRO Z790-P WIFI
Ram
Kingston FURY Beast 32 GB (2 x 16 GB)
Main storage
Kingston NV2 1 TB
Extra storage
Graphics card
Case
NZXT H510i
Power Supply
Corsair RM850x
https://linustechtips.com/topic/1575960-advice-for-first-computer-build/
1 minute ago, Blasty Blosty said:
Motherboard seems a bit overkill, unless you are planning to future-proof this build for a high-end drop-in later down the line
I am planning on this PC being the machine i can just upgrade CPU and GPU, and not worry about anything else
Use 2x 16GB sticks, not 1x 32GB
Right now it is cheaper for me to go 1x32 over 2x16, i was going to see which is cheapest on prime day and choose that. Would it still be better to go for 2x16?
It is not good for the framerate consistency to run single channel, but it depends on the resolution and the game. I think DDR5 is generally less affected than DDR4 because it has higher throughput than DDR4 anyway, but I haven't seen that many benchmarks.
The 12400 is pretty easy to cool, even though the stock cooler (in the CPU box) can do it without much trouble. A peerless assassin or phantom spirit wouldn't break a sweat.
20 minutes ago, GamersDontDie said:
Hi!
cpu
Cpu cooler
motherboard
MSI PRO Z790-P WIFI
Ram
Main storage
Extra storage
Graphics card
Case
NZXT H510i
Power Supply
Corsair RM850x
Cooler is overkill unless you really want one for looks
Get 2x16GB RAM not 1x32
Get a larger SSD, at least 1TB
PSU is overkill, but ok for a future 3080 (which isn't that good, rather get a 4070)
Yeah, if you stick with this mobo you can just drop in the best CPU later down the line and get a nice performance boost
Yes, there will be a performance boost with dual channel
Console.WriteLine("Hello World!");
