i recently built a brand new pc. but most games get less fps than i saw benchmarked online. fortnite gets around 180 fps performance mode.
Specs:
Operating system: Microsoft Windows 10 Home (10.0, Build 19045)
Processor: 13th Gen Intel(R) Core(TM) i7-13700K 16/24
Motherboard: Micro-Star International Co., Ltd. B760 GAMING PLUS WIFI (MS-7D98)
RAM: 32 GB
Storage1: Samsung SSD 970 EVO Plus 1TB (931.5 GB/Fixed hard disk media)
Storage2: WD Elements 2621 USB Device (931.5 GB/External hard disk media)
Graphics card1: NVIDIA GeForce RTX 4070 (12.0 GB)
Graphics card2: Intel(R) UHD Graphics 770 (2.0 GB)
GPU hits 100% when tabbed in
https://linustechtips.com/topic/1575911-far-less-fps-than-expected/
Pls post what says GPU-Z
Is the GPU in the topmost slot, Pcie4 x16 lanes, no riser cable ?
image.png.1a16a76e4bd64b225adf8c715aa437a4.png gpu is in right spot, im a noob idk what the other things are sorry
Urgg it runs on PCie3 x1 lane instead of PCie4 x16, it's crippled !!
Don't think it's in the right spot, pls post pic !
how do i check. sorry im kinda a noob. xmp is on
Either on your BIOS/UEFI or on your receipt all follow up the model online for the specs.
You’ll want to know the speed and timings. It’ll say something like 3600MHz and CL 18-22-22.
Sounds like your issue is the slot though. PCIe@1x3.0 is very not right. Check your motherboard manual to find out which slot is full bandwidth, but it should indeed by the top-most one closer to where your CPU is installed. Assuming I am looking at the right manual, there is only one PCIe 4.0 x16 slot and GPU-Z reports it is using that connection.
It is plugged directly into your motherboard’s PCIe slot, right?
Also, make sure Resizable BAR is turned on in your BIOS/UEFI. It appears you have it off.
i believe it is cpu cooling because furmark cpu burner gets to like 100 lmao
100% or 100 degrees Celsius?
100% is normal when in use for a benchmark or a game. Either 1 of your CPU cores will be maxed or your GPU will be maxed, unless you use frame limiting.
