Budget: 2500 CAD AFTER TAX (lower is preferred)
Country: Canada
Games, programs or workloads that it will be used for: Roblox, R6, newer games @ 2k resolution
Other details: My friend wants to build a pc setup, including monitors and a UPS, that will last him a year or two before needing to upgrade it, future proof parts are wanted so he wont have to get a whole new pc later on.
These are the parts I currently have chosen out, though I'm not sure where to save money without compromising too much performance. https://ca.pcpartpicker.com/user/pcel0l/saved/WQrs8d
https://linustechtips.com/topic/1575437-budget-pc-help/
Country: Canada
I'd go with something like this instead.  The AM5 platform is a lot more futureproof as you can upgrade to the 7800X3D or the upcoming 9800X3D from AMD.
The 7600 is faster than the 12400f in gaming and the 7600 comes with a stock cooler so no need for a cooler unless you want to buy one.
https://ca.pcpartpicker.com/list/xKscwg
https://linustechtips.com/topic/1575437-budget-pc-help/#findComment-16455858
for a budget build you are spending quite a buck on expensive things like fans
current PC:
PC configs I used before:
https://linustechtips.com/topic/1575437-budget-pc-help/#findComment-16455860
Agreed, AM5 is the way to go for future proofing.
https://linustechtips.com/topic/1575437-budget-pc-help/#findComment-16455878
Country: Canada
PCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($247.96 @ shopRBC)
CPU Cooler: *Thermalright Peerless Assassin 120 SE WHITE ARGB 66.17 CFM CPU Cooler  ($41.90 @ Amazon Canada)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  ($189.99 @ Amazon Canada)
Memory: *G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($139.99 @ Canada Computers)
Storage: TEAMGROUP MP44 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($315.99 @ Amazon Canada)
Video Card: XFX Speedster QICK 319 Core Radeon RX 7800 XT 16 GB Video Card  ($649.00 @ Canada Computers)
Case: SAMA ARGB-Q5 MicroATX Mini Tower Case  ($80.98 @ Newegg Canada)
Power Supply: *Deepcool PQ850M 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.99 @ Canada Computers)
Monitor: Gigabyte GS27QC 27.0" 2560 x 1440 170 Hz Curved Monitor  ($249.99 @ Canada Computers)
Monitor: MSI G2412F 24.0" 1920 x 1080 180 Hz Monitor  ($150.99 @ PC-Canada)
UPS: CyberPower CP1500PFCLCD UPS  ($276.99 @ PC-Canada)
Total: $2463.77
Generated by PCPartPicker 2024-07-02 16:00 EDT-0400
this list isn't great because it doesn't include tax as pc part picker doesn't take it into account
if we assume tax will be about a 20% increase in price for all parts then swap the 7800 xt for this used 6700 xt, gets you down to about $2200 CAD without predicted tax ASRock Challenger D Radeon RX 6700 XT 12GB GDDR6 Graphics Card (RX6700XT CLD12G) | eBay
we can do sub 2000 without tax, but no am5 with a 6700 XT+ performance card (which is quite essential for a high refresh rate 1440p gaming experience)
you can go down to a 5600/12400f with different mobo and still get a good experience for under 2000 without tax I just wanted to put in the 5700X3D to be as close to the 7600 performance as possible (while being as close as i could to 2000 without tax)
CPU: AMD Ryzen 7 5700X3D 3 GHz 8-Core Processor  ($279.00 @ Canada Computers)
Motherboard: ASRock B550 Phantom Gaming 4/ac ATX AM4 Motherboard  ($124.99 @ PC-Canada)
Memory: Silicon Power XPOWER Turbine 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($74.98 @ Amazon Canada)
Case: NZXT H6 Flow ATX Mid Tower Case  ($67.95 @ Amazon Canada)
Power Supply: Deepcool PQ850M 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.99 @ Canada Computers)
Custom: Used 6700 XT ($380.00)
Total: $2082.77
Generated by PCPartPicker 2024-07-02 16:09 EDT-0400
Edited by filpo
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1575437-budget-pc-help/#findComment-16455888
Alright good to know, thank you.
https://linustechtips.com/topic/1575437-budget-pc-help/#findComment-16455898
2 minutes ago, pcel0l said:
They'll last quite a while though.
you say your friend want the system to last at least one to two years before upgrading it. How about using the stock case fans in a case like this NZXT H6 Flow ATX Mid Tower Case (CC-H61FB-01) - PCPartPicker and then telling them to get fans similar to those in your original list in one to two years when they might upgrade
Total: £1040.95
https://linustechtips.com/topic/1575437-budget-pc-help/#findComment-16455899
Yeah that makes sense honestly, I'll probably do something like that then
https://linustechtips.com/topic/1575437-budget-pc-help/#findComment-16455902
sure, but you can get cheaper fans that are similarly quiet, and if you don't rack them 100%, they'll last you regardless most likely,
and you can get a case that has pre-installed fans for even cheaper, some cases can include even 4 pre-installed fans,
no monitors on this list:
CPU: *AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($247.96 @ shopRBC)
CPU Cooler: *Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler  ($46.90 @ Amazon Canada)
Motherboard: *MSI PRO B650-S WIFI ATX AM5 Motherboard  ($199.99 @ Best Buy Canada)
Video Card: *XFX Speedster QICK 319 Core Radeon RX 7800 XT 16 GB Video Card  ($649.00 @ Canada Computers)
Case: Montech AIR 903 MAX ATX Mid Tower Case  ($99.99 @ Newegg Canada)
Power Supply: SeaSonic FOCUS Plus Gold 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($139.99 @ Canada Computers)
Total: $2116.80
Generated by PCPartPicker 2024-07-02 16:14 EDT-0400
  • also why does your friend need an UPS?
current PC:
https://linustechtips.com/topic/1575437-budget-pc-help/#findComment-16455907
The UPS isn't a necessity, it would just be nice to have incase of power outages.
Yeah I'll probably switch to a case that has pre-installed fans.
https://linustechtips.com/topic/1575437-budget-pc-help/#findComment-16455912
could get that one later then, if power outage isn't something common in their area
check out the Montech one,
or these cases: (if you click the link of the list, you can see them in the filter)
Case: *Montech AIR 903 BASE ATX Mid Tower Case  ($65.00 @ Amazon)
Total: $65.00
Generated by PCPartPicker 2024-07-02 16:29 EDT-0400
current PC:
https://linustechtips.com/topic/1575437-budget-pc-help/#findComment-16455923
