Need help with bios and gpu
By
yobamas
in Troubleshooting
in Troubleshooting
Solved by Tetras,
Are you using an eGPU, or is this plugged in to your PC permanently?
Is your BIOS set to default to the dGPU?
voltigeurramon ·
Posted in Troubleshooting0 -
Vibora ·
Posted in New Builds and Planning4 -
4
3
Doctah ·
Posted in Peripherals3 -
6
michaelb198 ·
Posted in Peripherals2
